Hassio: login not working from custom domain with SSL
This may be similar to problem that occur when you try make www.yoursite.com/ha point to HA.
This never work for some reason explained in the thread below
This should not be issue if your subdomain only point to ha at /
If this is reverse proxy you may need ensure config is proper to support websocket
