Hassio supervisor: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
Were you able to find a solution for this? I’m in the same position currently and don’t know what to do
Thank you for sharing this. My installation is running in a VM, and using the .ova file (Supervised installation). Will I be able to fix the issue in the same way you did? I believe there are no Docker containers easy available for my install…?
You found a solution for your .ova Supervised installation?
ha su update
Dears,
I have the same problem for 1 week ago, it seems related with node red restarts (node red restarts each 15 minutes). I have hassio installation.
When node red restarts, I see the time, and then, when I go to the registers I can see the error:
23-11-05 20:39:32 WARNING (MainThread) [supervisor.addons.options] Option 'interface' does not exist in the schema for Samba share (core_samba)
23-11-05 20:39:32 WARNING (MainThread) [supervisor.addons.options] Option 'allow_anonymous' does not exist in the schema for Mosquitto broker (core_mosquitto)
23-11-05 20:39:32 WARNING (MainThread) [supervisor.addons.options] Option 'dark_mode' does not exist in the schema for Node-RED (a0d7b954_nodered)
23-11-05 20:39:32 WARNING (MainThread) [supervisor.addons.options] Option 'require_ssl' does not exist in the schema for Node-RED (a0d7b954_nodered)
23-11-05 20:43:06 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Cannot proxy websocket message of unsupported type: 257
23-11-05 20:43:06 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
23-11-05 20:43:08 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:10 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:10 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Node-RED is failed, restarting...
23-11-05 20:43:10 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_a0d7b954_nodered application
23-11-05 20:43:11 WARNING (MainThread) [supervisor.addons.options] Option 'dark_mode' does not exist in the schema for Node-RED (a0d7b954_nodered)
23-11-05 20:43:11 WARNING (MainThread) [supervisor.addons.options] Option 'require_ssl' does not exist in the schema for Node-RED (a0d7b954_nodered)
23-11-05 20:43:11 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/node-red/amd64 with version 15.0.0
23-11-05 20:43:12 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:14 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:16 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:18 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:20 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:22 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:24 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:26 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:28 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:30 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:32 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:34 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:36 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:38 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:40 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:42 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:44 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:46 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:48 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:50 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:52 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:54 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:56 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:43:58 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
23-11-05 20:44:00 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63950 ssl:default [Connect call failed ('172.30.32.1', 63950)]
Really I don’t know what I need to do, because node red continues restarting each 15 minutes, and if I perform a total restart of home assistant, then, node red waits a lot to start, I need to manually start node red, a lot of time, and when finally node red starts, these errors occurs each 15 minutes…
Please, any help about this?,
Thanks,
Jose
