Having problems adding Heatmiser thermostat to configuration.yaml
Hi all… hope I’m posting in the right place…
Hope someone can help me… I have 8 x Heatmiser PRT thermostats connected to 2 x Heatmiser UH8 (8 Zone wiring centre). One UH8 controls the manifolds upstairs and one downstairs. Everything is underfloor, air-to-water system. Hoping to use the Heatmiser Thermostat component in Home Assistant (https://www.home-assistant.io/components/climate.heatmiser ).
Can someone tell me how I connect this up to a RS232 -> IP (ethernet) converter? I can’t figure out where to connect one? Can anyone recommend one? Do I need 2 (one for upstairs and downstairs). Do I take a feed of the UH8 or take a feed of each of the PRT thermostats at the point where they wire into the UH8? How do I identify each thermostat?
Appreciate any help or point me in the right direction :slight_smile:
