Ok my NetMonitor died a while ago and have just got round to trying this integration. Many thanks @nigelc.
I purchased a Waveshare RS485 to ethernet converter as it has PoE builtin and meant easy connection to my network. Configured the RS485 settings as above. Also followed the initial actions on Github. However I’m getting the following errors:
Logger: homeassistant.util.loop
Source: util/loop.py:77
First occurred: 12:44:55 PM (1 occurrences)
Last logged: 12:44:55 PM
Detected blocking call to import_module with args ('custom_components.heatmiser_ndc.climate',) in /usr/src/homeassistant/homeassistant/loader.py, line 1303: return importlib.import_module(f"{self.pkg_path}.{platform_name}") inside the event loop; This is causing stability issues. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#import_module Traceback (most recent call last): File "<frozen runpy>", line 198, in _run_module_as_main File "<frozen runpy>", line 88, in _run_code File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module> sys.exit(main()) File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main exit_code = runner.run(runtime_conf) File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File "/usr/local/lib/python3.13/asyncio/base_events.py", line 712, in run_until_complete self.run_forever() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 683, in run_forever self._run_once() File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2040, in _run_once handle._run() File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run self._context.run(self._callback, *self._args) File "/usr/src/homeassistant/homeassistant/config.py", line 1055, in _async_load_and_validate_platform_integration platform = await p_integration.integration.async_get_platform(domain) File "/usr/src/homeassistant/homeassistant/loader.py", line 1107, in async_get_platform platforms = await self.async_get_platforms((platform_name,)) File "/usr/src/homeassistant/homeassistant/loader.py", line 1172, in async_get_platforms platforms.update(self._load_platforms(platform_names)) File "/usr/src/homeassistant/homeassistant/loader.py", line 1097, in _load_platforms platform_name: self._load_platform(platform_name) File "/usr/src/homeassistant/homeassistant/loader.py", line 1271, in _load_platform cache[full_name] = self._import_platform(platform_name) File "/usr/src/homeassistant/homeassistant/loader.py", line 1303, in _import_platform return importlib.import_module(f"{self.pkg_path}.{platform_name}")
In addition have this:
Logger: homeassistant.config
Source: config.py:1055
Platform error: climate - cannot import name 'HVAC_MODE_HEAT' from 'homeassistant.components.climate.const' (/usr/src/homeassistant/homeassistant/components/climate/const.py)
File "/usr/src/homeassistant/homeassistant/loader.py", line 1184, in async_get_platforms
import_future.result()
File "/usr/src/homeassistant/homeassistant/util/loop.py", line 201, in protected_loop_func
return func(*args, **kwargs)
File "/usr/local/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1026, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/config/custom_components/heatmiser_ndc/climate.py", line 17, in <module>
from homeassistant.components.climate.const import (
...<5 lines>...
ImportError: cannot import name 'HVAC_MODE_HEAT' from 'homeassistant.components.climate.const' (/usr/src/homeassistant/homeassistant/components/climate/const.py)
Anyone help with what I’ve done worng?
Many Thanks,
Andy
