yes.
Another that is a possible system killer is a template like:
{% set ns = namespace(domains=[]) %}
{% for d in states|groupby('domain') %}
{% set ns.domains = ns.domains + [d[0]] %}
{% endfor %}
{% set list = ns.domains|join('\n') %}
{{list if list|count < 255 else
list|replace('input','inp')|truncate(255,true)}}
I have 3 systems. Main system with all other integrations loaded and rather a large backend setup, and 2 smaller ones, dedicated for Z-wave (Aotec stick) and Mqtt, serving as the dedicated broker. The latter 2 to take away as much stress from the production system as possible.
All on 115.3 now. My production system immediately breaks upon loading this template, and grinds to a halt. I can only restart it using the command line.
This template didnt break sweat in 114. The other (Z-wave and Mqtt) can run it without obvious trouble, but of course they have practically nothing to trackā¦
I have to add the above template is not even the complete template sensor, but an attribute_template. Main value_template was the count:
{{states|groupby('domain')|count}}
Now these seem to get solved in 116, but I mention it here to be completely transparent
