If the template contains states it behaves like in the “old days” when we used entity_id: sensor.time to make the template evaluate every minute.
If the template contains states.DOMAIN then the template is evaluated more frequently (every second).
Frankly, I’m fine with #1 but I’m less certain about #2. Polling at 1-second intervals hardly seems like ‘throttling’, unless you have a boatload of sensors that normally report at sub-second intervals. Anyway, 0.117 will be an interesting release.
How is this even possible to begin with? I’ve always learned the HA state machine only updates each second?
Secondly, since the most entities per domain will be in the sensor domain most likely, which is where most of the issues are from, I hope this now lowered threshold will not re-introduce the issues of 115. Or, was the main cause for that the use of {{states|xxx}} after all
I may be wrong but I have a vague recollection of a recent release note indicating they reduced the duration of the system’s clock-tick (i.e. it’s now less than 1 second). As a result, you can now specify float values like 2.5 for time intervals (i.e. it now supports milliseconds).
… scroll down past the description of the new milliseconds option and you will find this:
Also, all time listeners now have microsecond precision as they are scheduled on the internal event loop, instead of the previous situation when it relied on the internal clock that triggered every second.
So it looks like I misspoke and the clock-tick is the same (1-second) but things now reference some other internal time standard to get microsecond resolution.
right, the internal event loop. Must be the same as what I now use here, upon Amelchio’s advice:
- delay: >
{% set delay = states('input_number.snooze_delay')|int * 60 %}
{% set spent = (now() - state_attr('script.play_wakeup_radio','last_triggered')).total_seconds() %}
{{ [0, delay-spent] | max }}
I was struggling to get an updating template (which this isn’t since it is using now() ) but this still works, because it is not ‘updated’ but uses the ‘internal timer’.
if found some earlier experiments with the expand() functionality compared to the ‘old way’ of writing that:
{{trigger.event.data.entity_id in state_attr('group.iungo_switch_switches','entity_id')}}
compared to
{{trigger.event.data.entity_id in (expand('group.iungo_switch_switches')|map(attribute='entity_id'))}}
note the second line not only is longer… but it listens to way more states, at least entered in the template editor. As we now know, it listens to all states it finds in that group, while, entered as is, the top one only listens to the group. And still, that lists all the identical entities, and works as expected in the automation, checking if the event.data.entity_id is in the list.
Now, which of the 2 would be more efficient? For this automation, it wouldn’t even have to listen to the states, it would merely need to check if its in the list, no matter the state it has.
This is unfortunately another confusing change for those that just moved to {% set x = states('sensor.time') %} but I think it is a great simplification going forward. Now all templates will mostly “just work” and one only has to understand the nitty-gritty of the template engine in quite specialized situations (like those situations being discussed in this thread).
You’re right, we still won’t have the ability to restrict a Template Sensor’s evaluation to just once a day. If the sensor needs to reset its calculation at the start of every new day (like what we were able to do using sensor.date), that ability is lost.
Suggestions to use an automation with a Time Trigger (to force evaluation of the Template Sensor on a scheduled basis) overlook the fact the sensor’s template will continue to evaluated according to the new rules and not exclusively by the Time Trigger. In other words, it doesn’t matter if the Time Trigger is set to evaluate the Template Sensor at midnight, whatever entities present within the sensor’s template continue to cause evaluations, throughout the day, whenever they change state.
The new way now() will be handled is a welcome improvement. It’s a convenient replacement for including this in the template: {% set x = states('sensor.time') %}
In fact, users with templates having both now()and the above will probably want to remove it to prevent doubling the number of evaluations per minute. In other words, the workaround suggested by this (now very long) thread will become redundant in 0.117.
To be clear, even with now() becoming a first-class citizen, we still won’t have the degree of control we had when entity_id was available. We won’t be able to constrain a template to be evaluated only once per minute (state-changes of other entities in the template will also cause evaluations) nor just once per day at the start of each new day. in addition, there’s no easy way to re-establish that behavior (short of creating a python_script).
Yes, thanks for that. I’ve also just responded to Paulus and Frenck .
Somehow I get the feeling I simply can not get across what is the loss of the current situation, and the only thing that gets focus is the gain ( which is admittedly there).
FWIW, they are not ignorant people; they do get your point. However, they appear to be purposely ignoring/dismissing it.
The pattern has been:
There's no problem.
If there is a problem, it's not that bad.
The problem affects very few people, so it's not a big deal.
The people who have the problem should work around it.
This isn't the place to discuss it (topic closed).
well, yeah, case is closed just now. ‘lacking concrete examples’
this is completely incomprehensible, and must be so discouraging, even for the dev that is exhausting himself trying to find options to reduce the amount of unnecessary updates as much as possible.
if decreasing with a ratio of 1439 to 1 isn’t sufficient enough, and pushed aside like this, I guess there’s no reason to try and discuss this any longer.
feels like being asked for proof of getting wet when stepping into the rain.
This should not be an issue; the now()-based update is more of a watchdog so it only kicks in if nothing else is updating the template for a minute. We actually set the delay to 60.5 seconds to handle this case without double updates.
The behavior you described plays directly to the point made by mf_social where it’s becoming more difficult (not less) to understand what influences a template’s evaluation.
The documentation will need to clarify the order of precedence. For example, if the template contains now()andstates my best guess is that states will cause per second evaluations and now() plays no part (not even once a minute). Is that correct?
So is that a confirmation or are you guessing too?
You said no one will need to understand it because it will be so easy to use. However, I wager people will want to understand why one small change to their template causes it to change from updating every second to once a minute. Pretty sure they will notice near real-time updates to a relaxed per minute interval … and ask why.
Nothing updates every second… it’s a rate limit described above. It updates when states change. See my diagram for clarification. Example: I have this template {{ states.light }}. If no light changes state in a 7 hour period… then the template never calculates. Conversely, if I get 15 state changes in 1 second, then you get a template update at the entrance and exit of that one second.
If you add now() to the example above, you’ll have a 1 second rate limit but you’ll get updates every 60 seconds if no update occurred over that duration.
