Is there a way to add a heater and a cooler to the generic thermostat?
Right now it seems like you can only chose either to do nothing or heat. Or you can do nothing or cool. But not do nothing, heat if too cold and cool if too hot.
Basically that I want to do is to simply set a temperature and HA decides if it should turn on the heater, the AC, or keep both off. (two different devices in my case - both pluged into zigbee outlets)
How do I do that?
