Heating Set Points
This worked a treat! Many Thanks :slight_smile:
This worked very well, however it seems to miss the fact the temperature is being reported back in decimal increments, for example:
The condition is asking for greater than or equal to, and this works, but for whole numbers only - if the set point is say 20 degrees, 20.1-20.9 is ignored, its only when 21 is reached the state changes.
Any ideas?
Please try this
alias: Heating Controls
description: ''
mode: single
  - platform: time_pattern
    seconds: /10
condition: []
  - choose:
      - conditions:
          - condition: template
            value_template: >-
              {{state_attr('climate.living_room', 'current_temperature') | float <
              state_attr('climate.living_room', 'temperature') | float}}
        sequence:
          - service: (put the actions you want with current_temperature is less than set_temperature)
            data: {}
      - conditions:
            value_template: >-
              {{state_attr('climate.living_room', 'current_temperature') | float >
        sequence:
          - service: (put the actions you want with current_temperature is more than set_temperature)
            data: {}
    default: []
So this worked, however if i set the set point to 20 degrees, the boiler remains on until it reaches 20.5.
It looks like its missing the “equal to” condition, however i added in a “=” and this didnt work?
Any ideas?
What if the set point is 20.0?
{{state_attr('climate.living_room', 'current_temperature') | float >=
{{state_attr('climate.living_room', 'current_temperature') | float <=
This didnt work, but i solved it - the “off” action should be “equal to or greater than” whereas the “on” should only be “less than”.
Thanks again for your help.
Russell.
Hey, me again! Sorry :wink:
How would i go about using this code to fire an automation every time the temperature changes? By this, i mean every time a thermostat reports a change in state (so any state change), the automation fires? I am trying to remove the /30 second firing from the trigger to make things more robust (and prevent my log from bring crammed full of triggers).
Thanks.
Try changing the trigger to this.
  - platform: state
    entity_id: climate.living_room
    attribute: current_temperature
  - platform: state
    attribute: temperature
Thanks. That works.
