@mobile.andrew.jones You may add it to the schedule_prepend section and check against a given list of room names in the expression…
- temp: Break() if room_name in ("foo", "bar", "baz") and is_on("input_boolean.away") else Skip()
Or by exclusion:
- temp: Break() if room_name not in ("cooling") and is_on("input_boolean.away") else Skip()
By saying easier to configure I actually mean remove options that just blow up the documentation without adding real value, such as the master switch, for instance.
Heaty will continue to work simultaneously, because the latest Heaty v0.17.0 is included in that branch as well.
I’ll update the docs bit by bit during the weekend and they’ll be online instantly. Use the upgrading instructions for GitHub-based installations to fetch code updates.
Please be brave, test and - of course - have fun with Schedy!
Ok, the switch and thermostat docs are complete. The docs for the custom and generic actor types have stilll to be written, but that’s not too much work and I’ll do it tomorrow.
Ok thanks. Yes I had not restarted appdaemon. Somewhere I read it was not necessary but that will be after it has been restarted the first time .
A comment on the structure, having a schedule per room means everything happens at the same time and also means that every actor has to be doing the same thing. If I have a thermostat and a switch in the room, they will have different values and need different schedules.
To control both, I’d need to create ‘virtual’ rooms.
Ah so I have it working sort of (added in an actor type).
I was expecting this to turn a switch off between the times and on otherwise. It is doing the opposite…
If you use the switch actor type, that should work.
Rooms are in fact a virtual concept to group actors that should behave identical together. It is also only one actor type allowed per Schedy instance… It’s all explained in the docs really.
Apart from the custom actor type that probably will be used rarely anyway, the documentation is complete.
I’ve merged Schedy over to the master branch, hence the usual installation instructions for the development version as written in the docs now count for Schedy as well.
My local time is 10:50 (UTC+1). Using this schedule, the switch is set to ‘off’ on initialisation. If I change the on time to 09:36, the switch initialises to ‘on’
Schedy seems to be working to the same time as the log timestamps (which are UTC). I’m not sure if these should be local or UTC which may point to my problem.
Then your system time zone is probably wrong. Please run
date
and post the output. If it’s a Debian-based system, you can configure the timezone with
sudo dpkg-reconfigure tzdata
Edit:
I’ve actually not set a timezone in appdaemon.yaml at all, just configured it in Home Assistant as Europe/Berlin in my case. And the system time zone is of course set correctly as well.
Edit 2:
I see you’re already discussing this in another thread and you’re using hassio. Schedy is definitely not the problem in your case, since AppDaemon gets a wrong time zone. Otherwise, its logs would be in local time as well. So you need to set the correct time zone in Home Assistant. Good luck.
Is there a way of setting attributes 1,2 & 3 of an entity to x, y & z at one period of time, then set those attributes to a, b & c at a different period of time using Schedy?
Possibly I am going about this the wrong way
I have also tried to use the thermostat actor on a generic thermostat. What attribute does the thermostat actor set with the value value?
Attributes aren’t just set, that wouldn’t trigger any action. The appropriate services are called instead. The thermostat actor’s documentation describes quite comprehensive which services are called with which attributes.
For your other issue, you need to use the custom actor type and implement the actions needed to set the desired attributes yourself. Read the docs. I plan to add an example custom actor sometime, but don’t have time right now.
