@teqqy But then I don’t know how to help with that. A climate entity in HA basically supports setting a target temperature and that’s it. If you can determine a target temperature to send to the thermostat based on your room sensors, then you could express that logic and use it in a schedule in Schedy.
Thanks for help - I did this but am still unsure why I get “Unknown HVAC mode 'auto'
” error with these settings:
supports_hvac_modes: true
hvac_mode_on: "auto"
hvac_mode_off: "OFF"
Logfile:
2020-10-09 19:10:39.967474 INFO schedy_heating: --- [R:bathroom] Unchanged HA state: state='OFF', attributes={'actor_wanted_values': {'climate.thermostat_downstairs_bathroom_climate': 'OFF'}, 'scheduled_value': 'OFF', 'rescheduling_time': None, 'overlay_active': False}
2020-10-09 19:10:41.396595 INFO schedy_heating: --> [R:bathroom] [A:climate.thermostat_downstairs_bathroom_climate] Attribute 'state' is 'auto'.
2020-10-09 19:10:41.401282 ERROR schedy_heating: !!! [R:bathroom] [A:climate.thermostat_downstairs_bathroom_climate] Unknown HVAC mode 'auto', ignoring thermostat.
You know that these settings are actor-specific and thus have to be configured on the individual actors, right? If you want to set it for all actors, use the default actor template (just search for actor_templates).
EDIT: And you really shouldn’t fiddle with the other settings. The only thing you need is hvac_mode_on: "auto"
Is there a way to have a “tiered” heating system with schedy? What i a mean is that i have a heat pump (climate actor 1), and some electric ovens (climate actor 2).
I want to have a system where
1, just before i get home, the heat pump runs at fill speed.
2. When getting home, it has the the same temp, but now runs in silent mode
3. In some instances (for instance, temperature is low and the visitor mode is on) I only want to use the electric ovens, since they are totally silent.
Is this something that is somewhat manageable to do in schedy?
Hi @roschi,
I searched for a feature request section but didn’t found anything so I put my suggestion here.
I think it would be great if schedule_prepend
would have a “delay” of 5 min for exable because I noticed that for example in my doors-windows triggers valves many many times each days after each status change.
Do you found this intresting?
Thank you
Hi @roschi – I am trying to build an automation system for my HVAC system; I have 12 thermostats, 8 are heat/cool and 4 are heat-only that I want to program, and Schedy looks like the right tool, maybe. It sounds like I need the generic2 for the 8 heat/cool thermostats, which is fine. I definitely want to set them up into rooms, and then have probably 4 time-windows per weekday/weekend plus a vacation mode.
Here’s where I want to do something different: I want to be able to control the temp settings from the thermostats themselves. If I put the temp up a degree in a room, I want the schedule to get updated to reflect that. I know how to do that, but what I need are:
- A way to determine what Schedy room a thermostat is in, and
- A way to determinate which schedule-bucket I am in
I can do #2 from the HA side (as I plan to have those settings in HA), but #1 i there a way to do #2? Is there a way HA can query Schedy to ask what room a thermostat entity belongs to?
Thanks!
Hi @warlord
Have you seen the replicate_changes
room setting (docs). It is enabled by default and seems to do what you want without any manual automation work.
Hi @roschi –
I’m not sure that really does what I want. The docs say it will replicate changes from one actor to other actors in a room:
# This setting controls whether changes reported by one actor
# should automatically be replicated to the other ones in this
# particular room.
#replicate_changes: true
But that’s not what I want. I have two thermostats tied to my Master, a heat/cool MasterBR, and a Heat-only MasterBath. Let’s say it’s 7am on Monday and it’s cold in the room, so my wife increases the BR thermostat setting from 68 to 69 (at the thermostat controller on the wall, not in HA). I want that change to be “permanent” for the 7am time-bucket on weekdays. I don’t necessarily want the Master Bath changed – that’s set to something different (and needs to remain different). Then as the temp changes throughout the day from the schedule, each time-bucket for the room adjusts the thermostats (this would be Schedy doing its thing). Then at the 7am bucket the next morning it would be 69, instead of the previously-set 68.
But as the time-buckets are room-related and not thermostat-related, I need to be able to query Schedy to determine the room a thermostat is in so I know which time-bucket settings to query to determine which setting(s) to manipulate.
I do agree that Schedy would be a “better” place to do this, IF Schedy had a lovelace integration that would allow me to control the times and temp settings from the HA UI.
I admit that I’m new here, I’ve only spent an hour or so reading through the docs, so I’m sure there’s a lot that I am missing. And it’s clear that Schedy will do all the “take my stored settings and set my thermostats at the right times” work. If I didn’t want to allow saving local changes then it would completely solve my problem
Thanks!
@warlord I see, you really meant what you wrote.
First you have to keep in mind that you will need two instances of Schedy, one for the heat/cool thermostats and one for the heat-only ones. This is because each Schedy instance will use the same actor type for all its rooms. You could probably get away with just a single instance if you’re using generic2 for everything, but that could get a bit fiddly considering that you need different schedules for the two thermostat types.
Regarding the updating of schedules, I would use the schedy_room.<app-name>_<room-name>
entities, which Schedy stores the current state of a room in. From these entities, you can get the currently wanted temperature (state
). Right now, the actual room name is not available as an attribute of these entities, but if you set a room’s friendly_name
to the same value as the room name itself, that will be available as an attribute on these entities and you can use it to index your schedule storage by rooms. Of course this is a workaround, but for now it should be fine. I could add app_name
and room_name
attributes which provide the particular values directly in next release.
I’m afraid this won’t happen any time soon, maybe not even at all. Schedy schedules are more of a scripting language than plain time/weekday scheduling, thus I don’t think there’s an intuitive GUI-based way to configure it without ending up with some text input for code again after all. Of course one could build a GUI for classic weekday scheduling which uses Schedy under the hood, but if that’s all you want you don’t really need Schedy.
The supposed way of making Schedy configurable from HA is to create use case-specific input_*
entities which are referenced from the fixed Schedy schedules and control Schedy’s behavior that way. Then you can organize these entities in cards however you think it best reflects your use case.
HTH
I do want something a little more complicated than just time + weekday/weekend scheduling – I do want to add vacation mode, too. Because I have so many rooms to keep track of, and no way to build a macro in HA, I was thinking it would be nice to put it elsewhere. (Write Once, Use Many). Being able to use schedy_room.<app_name>_<room_name>
might be able to help…
Thanks!
@roschi, is it possible to use sunrise or sunset directly in a rule? It seems to not parse correctly as an end
value.
@baz123 No, not possible so far. Please query the sun.sun
entity in an expression or, if you need offsets, create template binary sensors or similar.
Hi there,
Would it be possible to use the native rooms feature in HA instead of mapping the sensors to rooms in customize.yaml
Bye,
Jo
@chbndrhnns Hmm, good question, I guess you’re referring to the areas feature introduced around v0.100 or so?
I never used that myself, do you know whether the area an entity belongs to is provided as an attribute of that entity? If so, you could just change the comparison of the custom window_room
attribute accordingly…
I just found the corresponding issue in AppDaemon to add support for areas. It seems it has not yet been added.
I’m looking to start using Schedy to control my evohome system.
Last week I also installed 4 airconditioning units into my home and have integrated them with HA.
I want to create some kind of dependability so that if the airconditioning is turned on > the heating in that room is automatically switched off (would kind of be a waste of energy otherwise ).
If that is possible, perhaps also something like this: Set a specific temperature per room on a scheduled basis. And then let Schedy decide if it’s too hot in the room > Turn on A/C. Or if it’s too cold in the room > Turn on Evohome. Perhaps take into account some weather forecast / outside temperature as well? >_>
Does anyone know if this is at all doable in Schedy? Can’t really figure it out through docs alone…
Suggest using an automation for that. I ended up using some boolean sensors to override behaviour as well. Don’t try and do everything in schedy!
