Why does your automation have 5 separate choose
statements (each with a single conditions
) instead of a single choose
statement (with five conditions
I just did it with the visual editor under the automation, i think i took the easy path. But it is a still in progress job, if you see how i can improve it I’ll definitely take any advice
Sure, use the example I originally posted and simply modify it.
alias: bathroom experiment
description: ''
- platform: state
entity_id: group.bathroom_motion
to: 'on'
for:
hours: 0
minutes: 0
seconds: 0
- platform: state
to: 'off'
for:
hours: 0
minutes: 3
seconds: 0
- platform: state
to: 'off'
for:
hours: 0
minutes: 10
seconds: 0
- platform: state
entity_id: group.bathroom_door
to: 'on'
- platform: state
entity_id: binary_sensor.bathroom_hygrostat
to: 'on'
for:
hours: 0
minutes: 1
seconds: 0
- platform: state
to: 'off'
for:
hours: 0
minutes: 5
seconds: 0
condition: []
- choose:
- conditions:
- condition: trigger
- condition: state
entity_id: light.bath_light_on_off
state: 'off'
sequence:
- service: light.turn_on
data: {}
- conditions:
- condition: state
state: 'off'
sequence:
data: {}
- conditions:
- condition: state
state: 'on'
- condition: state
state: 'on'
sequence:
- service: light.turn_off
data: {}
- conditions:
- condition: state
state: 'on'
- condition: state
state: 'off'
sequence:
data: {}
- conditions:
- condition: state
state: 'off'
- condition: state
state: 'on'
sequence:
- service: switch.turn_on
data: {}
entity_id: switch.tz3000_ji4araar_ts0011_4c755449_on_off
- conditions:
- condition: state
state: 'on'
sequence:
- service: switch.turn_off
data: {}
default: []
mode: single
ok following your advice, I have this now
Not sure why you discarded the example’s use of variables
and converted all of the shorthand Template Conditions into longer State Conditions. All you needed to do was copy-paste the example and then change the entity names (a 1 minute operation).
I tried with the variable but this shows up “Message malformed: expected a dictionary for dictionary value @ data[‘action’][0][‘variables’]”
Based on the the appearance of the unformatted YAML you posted initially, I believe that error message was due to incorrect indenting. The three variables under variables:
should be indented; your example shows all three are vertically aligned with variables:
and that’s invalid.
alias: bathroom experiment 2
description: ''
- platform: state
to: 'on'
- platform: state
to: 'off'
for: '00:03:00'
- platform: state
to: 'off'
for: '00:10:00'
- platform: state
to: 'on'
- platform: state
to: 'on'
for: '00:01:00'
- platform: state
to: 'off'
for: '00:03:30'
condition: []
- variables:
light: light.bath_light_on_off
fan: switch.tz3000_ji4araar_ts0011_4c755449_on_off
door: group.bathroom_door
- choose:
- conditions:
- '{{ trigger.id == ''occupancy''}}'
- '{{ is_state(light, ''off'') }}'
sequence:
entity_id: '{{ light }}'
- conditions:
- '{{ trigger.id == ''door_open''}}'
- '{{ is_statte(light, ''off'') }}'
sequence:
- conditions:
- '{{ trigger.id == ''no_occupancy_3''}}'
- '{{ is_state(light, ''on'') }}'
- '{{ is_state(door, ''on'') }}'
sequence:
- conditions:
- '{{ trigger.id == ''no_occupancy_10''}}'
- '{{ is_state(door, ''off'') }}'
sequence:
- conditions:
- '{{ trigger.id == ''shower_on''}}'
sequence:
entity_id: '{{ fan }}'
- conditions:
- '{{ trigger.id == ''shower_off''}}'
- '{{ is_state(fan, ''on'') }}'
sequence:
default: []
mode: single
you were totally right, it was incorrect indenting, but I think I got it right this time
For future reference, when someone gives you an automation that solves your problem, or meets the requirements of your request, that’s the post that represents the Solution. Only one post in the entire thread can represent the Solution. In this case, you took the example I posted, changed the entity names, then marked your own post as the Solution. For more information, refer to guideline 21 in the FAQ.
Im sorry i did not know that but I fixed alredy
