I have had my Raspberry Pi 3 B running for a week. HA also and it found the Bluetooth hardware and automatically configured my Govee thermometers. However, late Tuesday they became unavailable. I powered the System down and the Govee devices seemed to get going again, but not for long. I have tried restarting HA but no good. Today I uninstalled Bluetooth and now when try to reinstall it it says ‘No unconfigured adaptors found. There are zero ignored adapters.’ On Tuesday afternoon I installed HA OS and Core in the order I received the update notifications. To determine if the hardware was faulty I ran the bluetoothctl program using Terminal. It reported the Govee devices and plenty more.
I do have Integrations for Myenergi (Zappi EV charger), SolarEdge, and Midea_ac_lan and have recently configured the Energy Dashboard including adding some Reimann Integration helpers for kW to kWh. I also installed HACS.
Io ho risolto con le striscie della govee modificando la comunicazione della API e HA
Impostazioni
Dispositivi e servizi
integrazioni (Govee)
configura
Poll Interval 240
disabilita la spunta su WHEN E LED OFFLINE,SHOW ITAS OFF…
Disable state updates. space to disable. read the Redame above!
api:power_state
Queste le mie configurazione per Govee
Thank you for replying. I can’t see the options to lengthen the poll interval etc with my Govee Bluetooth integration. All I see is the list of devices with the Configure option for the service.
