Do you care about time, or number of measurements? Time is easy, with the for:
parameter in the numeric state trigger.
If it must be the latter, you will find some difficulties when a new measurement comes in the same as the last — that won’t, by default, fire any triggers.
See the State Object docs: you might need to create a template sensor helper that mirrors the last_reported
property of the meter.
{{ states.sensor.YOUR_METER.last_reported }}
Then build a “value cascade” sensor like this that triggers from your new template sensor and records the current air quality measurement with n
“slots”.
Next, create a template binary sensor helper that checks if slots of your cascade sensor are above k
(here, for k
=5, with the 999 to filter out anything that can’t be converted to float, like the last_updated
attribute):
{{ states.sensor.YOUR_CASCADE.attributes.values()|map('float',default=999)|select('<=',5)|list|count == 0 }}
Trigger your automation from that binary sensor.
If you want further help, please provide the entity IDs for your sensor and switch, as well as values for k
, n
, x
and i
