malosaa
(Hector)
November 26, 2022, 4:05pm
21
Yes i did use sqlite3-to-mysql to convert the db
so that happens when i import into MARIADB.
as when it has imported all stats are good, but when homeassistant updates new value i get it messed up.
See above screenshot.
first screenshot is my main system and second screenshot is my test system. u can see the difference
malosaa
(Hector)
November 26, 2022, 4:10pm
22
Also i did notice this, looks like it went to 0 after the migration ?
This is from the migration
My original system
screenshots mean didley squat to me, old-school-guy needing table-data
EDIT: and please indicate which part was imported and which was created after
malosaa
(Hector)
November 26, 2022, 4:24pm
24
WHat query can i use, i’m not good with sql
in statistics_meta, find the “id” that belongs to the device’s cost…please only 1
Then
select * from statistics where metadata_id = id-from-above
malosaa
(Hector)
November 26, 2022, 4:26pm
26
Ok ill check,
here see this,
i hanged the second row to where it needs to be, and now when consuming gas it resets again
I would like to see what/where the diff starts with the cost as this SHOULD be very simple to migrate but… I know HA calculates not always logically
malosaa
(Hector)
November 26, 2022, 4:33pm
28
this is from the migration one
the otherone uses the default hass db.
i did run the query but it returned old data and nor recent updated data
my main system
You do understand that I have no clue about what you do , how and what your DB looks like neither how sort/prin screenshots…
Anyhow, from the 2nd picture, if this is the ‘costs’ one, then ONLY for the 26th this is already not correct line 3: 714.96 + 0.076 should lead to 717.605…which logically it is not, please add a sort on create desc
malosaa
(Hector)
November 26, 2022, 4:41pm
31
So it did reset somehow, whike my main system is still at the 22th and the test system at the 26th
malosaa
(Hector)
November 26, 2022, 4:44pm
32
This is the query i used on both
SELECT * FROM statistics
WHERE metadata_id =5 Order By last_reset Desc
I am lost…really…
Please export from the migrated data, the costs records with YOURID
To not export all, you can create a new table ‘test’ in SQL of phpmyadmin
create table test select * from statistics where metadata_id=YOURID
then use export for the test table and attach here
malosaa
(Hector)
November 26, 2022, 4:46pm
34
Here the created row from my main
and this from my migrated one
I need all, screenshots suck for analysis
and maybe you can do the same from the original SQLite, with dbbrowser you can export tables too
malosaa
(Hector)
November 26, 2022, 4:52pm
37
here it is
https://www.dropfiles.pro/gcnqAIC6yEMY9ET
and here the one from may main system, but in json format.
as it only let me export to json
https://www.dropfiles.pro/7X0NDMgaZWhshIx
malosaa
(Hector)
November 26, 2022, 4:53pm
38
i needed to upload it because its not accepted, also no rar files sadly…
how can i use that query on sqlite as it doesnt work there
updated above post
VERY quick look, this is indeed not as I would expect it
state should add to sum and this is not at all showing… note I am not 100% sure as this I never did but I am basing it on looking at my costs-sensor
can you send me the source too
in sqllite it is slight different
create table test_source as select * from statistics where metadata_id = YOURSOURCEID
sourceid may not be 5 ?
From dbbrowser (if you use that) you can then export test_source
And, what is your current CORRECT running total , the first set indicates 730, i.e. for 2022 you should see roughly 678 EUR (or whatever currency you use)
