Help needed with light transition
This is what I have now… and it does nothing!
input_boolean:
  ib_fishtank01_brightness_overide:
    icon: mdi:arrow-collapse-up
input_number:
  in_fishtank01_brightness_level:
    initial: 0
    min: 0
    max: 256
    step: 1
    mode: box
    icon: mdi:arrow-expand-vertical
automation:
  - alias: au_fishtank01_brightness_overide_timer
      - platform: state
        entity_id: input_boolean.ib_fishtank01_brightness_overide
      - service: script.turn_off
        entity_id: script.sc_fishtank01_overide_timer
      - service_template: script_{{trigger.to_state.state}}
  - alias: au_fishtank01_adjust_brightness
      - platform: state
        entity_id: input_number.in_fishtank01_brightness_level
      - platform: state
      - platform: time_pattern
        seconds: '/80'
      - service: script.sc_fishtank01_calc_level
      - delay: '00:00:01'
      - service: light.turn_on
        entity_id: light.0x680ae2fffeb18442_light
        data_template:
          brightness: "{{ states('input_number.in_fishtank01_brightness_level') }}"
          transition: 10
script:
  sc_fishtank01_overide_timer:
    alias: FT Overide Timer Script
    - delay: "00:20:00"
  sc_fishtank01_calc_level:
    alias: Fish Tank 01 Calc Brightness
      data_template:
        value: >
          {% set ovrd = is_state('input_boolean.ib_fishtank01_brightness_overide', 'on') %}
          {% set tnow = as_timestamp(now()) %}
          {% set frm12 = tnow - as_timestamp(now().strftime('%Y-%m-%d ' ~ '12:00')) %}
          {% set frm17 = tnow - as_timestamp(now().strftime('%Y-%m-%d ' ~ '17:00')) %}
          {% set frm22 = tnow - as_timestamp(now().strftime('%Y-%m-%d ' ~ '22:00')) %}
          {% set cnt = frm22 < 0 <= frm12 %}
          {% set rise = cnt and frm17 < 0 %}
          {% set fall = cnt and frm17 >= 0 %}
          {% set outp = 0.0 %}
          {% if ovrd %}
            {% set outp = 255 %}
          {% elif rise %}
            {% set outp = frm12 / 80 + 30 %}
          {% elif fall %}
            {% set outp = 255 - frm12 / 80 %}
            {% set outp = 0 %}
          {{ (outp + 0.5) | int }}
see my post just above yours
it did work, it’s just that your input number didn’t like having -39 assigned to it (0 to 256 range) not sure why I did the 256 now, could get away with 255
Amended that, but still nothing after a server reboot.
input_boolean:
input_number:
    initial: 0
    min: 0
    max: 256
    step: 1
    mode: box
automation:
      - platform: state
      - platform: state
      - platform: state
        seconds: '/80'
      - delay: '00:00:01'
        data_template:
          transition: 10
script:
    - delay: "00:20:00"
      data_template:
        value: >
          {% if ovrd %}
          {% elif rise %}
          {% elif fall %}
            {% set outp = 255 - frm17 / 80 %}
            {% set outp = 0 %}
can you display the input number ?
can you see if it changes ?
do you have any errors ?
This value doesn’t change:
Screenshot_2020-03-14_18-58-25
Brightness override not working either.
I reiterate : -
Do you have control the lovelace ?
Just insert
No, it just displays 123, which isn’t the actual value the dimmer is currently at, and changing this through the interface doesn’t change the levels and the value jumps back to 123
Screenshot_2020-03-14_19-56-07
UPDATE: The value is not showing 120, so maybe it’s ramping down? It doesn’t look like actual dimmer value is changing however.
Turning on brightness override sets the above value to 255, however it does not change the light level.
It looks like all the functions are working but not sending the values to the dimmer controller
That’s what we are trying to determine.
Monitor the number, it ‘should’ basically change every 80 seconds and go to 30 at 22:00 and jump to 0 and stay that way till 12:00 tomorrow jump to 30, ramp up, ramp down, rinse and repeat.
Check you don’t have this light anywhere else in you automations
The number is going down, it’s now 97, but it’s not dimming the light.
It does not appear to be sending the value to the dimmer, as neither the decreasing values nor the override have any effect on the dimmer.
Check that the name of the light in the automation is exactly the same as your actual light
Screenshot_2020-03-14_20-55-28
From package:
      - delay: '00:00:01'
        data_template:
          transition: 10
From automation with delays (working):
  - data:
      brightness: 11
  - delay: 00:00:10
  - data:
      brightness: 255
      transition: 18000
  - delay: 00:00:18000
  - data:
      brightness: 11
      transition: 18000
  - data: {}
    service: light.turn_off
Edit : There is a problem with brightnes: vs brightness_pct: (No Idea Why) Please go down to Post 95 for the workaround
I’m doing some experiments.
As an aside :
@jwelter if you look at the entities created you will see that the code is based on useage of an editor that reads your whole configuration for autocomplete ability (like VSC) so my file would be called fishtank01.yaml
if I ever need to change the config for in_fishtank01_brightness_level I know I can find it in the fishtank01 file
Also when I’m typing and I want to use an entity, I start typing “inp” and options come up for input_boolean, input_number, input_select etc. I just click the one I want
hit “.” and all the input_numbers (in this case) come up. As I type the list is narrowed.
the ‘in_’ is just for easy recognition in entities lists (and it also helps in scanning through lists as alphabetically I will know where to find them), the next bit is the package, then what I’m using it for.
It makes coding a LOT faster.
@bedfellow so, I don’t actually use brightness, I use brightness_pct and when I cenvert the package to brightness_pct it works (not been through a full day yet though.
Here is my ‘modified’ package I’m testing with : -
input_boolean:
input_number:
    initial: 0
    min: 0
    max: 255
    step: 1
    mode: box
automation:
      - platform: state
      - platform: state
      - platform: state
        seconds: '/80'
      - delay: '00:00:01'
#        entity_id: light.fishtank01_level
        entity_id: light.fibdim2_lgl1_level
        data_template:
          brightness_pct: "{{ states('input_number.in_fishtank01_brightness_level') }}"
          transition: 10
script:
    - delay: "00:20:00"
      data_template:
        value: >
          {% if ovrd %}
          {% elif rise %}
          {% elif fall %}
            {% set outp = 0 %}
          {{ ((outp + 0.5) * 100 / 255) | int }}
It seems to be a tiny syntax discrepancy which I can’t find. hopefully @anon43302295 , @123 , @finity or @pnbruckner could cast an eye over the two and point out exactly where I have f****d up :face_with_symbols_over_mouth:
Sorry about this, I thought the two were more of less interchangeable. If necessary I can rewrite this again using pct and reducing your processor load.
Sorry, no, I left this thread many posts ago. I’m sure you’ll solve it. Good luck.
Okay, I found a thread with a solution to brightness: using a template by pnbruckner.
I remeber reading that ‘some’ devices are picky about specific indentation and don’t seem to follow normal rules, as the above shows.
I changed tthe syntax accordingly but still no joy.
I’ve given up
It does work for pct so I’ve modified the package for that.
Using 0 = off, 11 = minimum brightness, 100 = maximum, then over 5hrs (18,000 seconds) that’s a step every 202.247 (and some change). So I set the update to 101 (more than twice the required frequency but still a saving on the previous).
As the entity definitions have changed, it will require a restart
input_boolean:
input_number:
    name: Brightness (percent)
    initial: 0
    min: 0
    max: 100
    step: 1
    mode: box
automation:
  - alias: au_fishtank01_brightness_overide_on
      - platform: state
        to: 'on'
      - service: script.sc_fishtank01_overide_timer
  - alias: au_fishtank01_brightness_overide_off
      - platform: state
        to: 'off'
      - platform: state
      - platform: state
        seconds: '/101'
      - delay: '00:00:01'
        data_template:
          transition: 5
script:
    - delay: "00:01:00"
      data_template:
        value: >
          {% set date = now().strftime('%Y-%m-%d ') %}
          {% set frm12 = tnow - as_timestamp(date ~ '12:00') %}
          {% set frm17 = tnow - as_timestamp(date ~ '17:00') %}
          {% set frm22 = tnow - as_timestamp(date ~ '22:00') %}
          {% if ovrd %}
            {% set outp = 100 %}
          {% elif rise %}
            {% set outp = frm12 / 202.247 + 11 %}
          {% elif fall %}
            {% set outp = 100 - (frm17  /  202.247) %}
            {% set outp = 0 %}
Again the light used is a test lamp so you will have to replace that with “your light”
PLEASE ensure you delete (or at least comment out all other instances of turn on/off etc of your light entity, as I said before this should do the lot.
I’ll await someone a ‘LOT’ wiser than I (sets the bar pretty low) to explain what’s going on with brightness vs brightness_pct
I’m playing with at Tasmota RGBCT light.
What you have there looks like the second step to me.
From what I have working you need to add two data sections:
  - data:
      brightness_pct: 12
  - data:
      brightness_pct: 100
      transition: 18000
  - data:
       brightness_pct: 12
      transition: 18000
It might be you need a delay between the steps (I could be imagining it but it seems to help for some of my transitions)
  - delay:
      seconds: 1
I did this today. Got the code from a YouTuber and slightly modified it. It’s so flexible - you could do whatever you want.
input_number:
  dining_room_morning_light:
    name: Dining Room Motning Light
    initial: 5
    min: 5
    max: 150
    step: 1
script:
  dining_room_morning_lighting:
      - repeat:
            - service: script.dining_room_lights_w_level
                  level: '{{ states("input_number.dining_room_morning_light") }}'
                  colortemp: 400
            - service: input_number.increment
              entity_id: input_number.dining_room_morning_light
            - delay: 00:00:15
          until:
            - condition: template
              value_template: '{{ states("input_number.dining_room_morning_light") | int == 150 }}'
          value: 5
  dining_room_evening_lighting:
            level: 255
            colortemp: 270
  dining_room_lights_w_level:
        entity_id: light.dining_room_main_lights
          brightness: >
            {{ level | int }}
          color_temp: >
            {{colortemp}}
I recently had to do the same thing for a powerhead in my aquarium, I wanted to ramp up/down the speed over an hour however it wouldnt work using the transition command. I ended up using the repeat command to increase the percentage every x minutes.
So in your case since you want it to ramp up 88% over 18000 seconds you would need to increase the light 1% every 204 seconds (3 min & 24 seconds). So try the following:
alias: light-ramp-up
description: ""
  - platform: time
    at: "00:00:00"
condition: []
      brightness_pct: 12
      entity_id:  your light
  - repeat:
      until:
        - condition: numeric_state
          above: 99
            brightness_step_pct: 1
        - delay:
            hours: 0
            minutes: 3
            seconds: 24
            milliseconds: 0
to ramp back down:
alias: light-ramp-down
description: ""
  - platform: time
    at: "05:00:00"
condition: []
      brightness_pct: 100
  - repeat:
      until:
          below: 12
            brightness_step_pct: -1
        - delay:
            hours: 0
            minutes: 3
            seconds: 24
            milliseconds: 0
then add an action to turn off the light or set it to 12%
