Not sure 18000/255 may mean that it will reach 255 before 5hrs given the resolution
255 is 100% brightness
Does this look correct?
- id: '1584046806268'
alias: Marine Tank Dimmer
description: ''
- at: '12:00'
platform: time
condition: []
- service: light.turn_on
entity_id: light.0x680ae2fffeb18442_light
brightness: 30
- wait_template: "{{ is_state_attr('light.0x680ae2fffeb18442_light' , 'brightness' , 30) }}"
brightness: 255
transition: 18000
- wait_template: "{{ is_state_attr('light.0x680ae2fffeb18442_light' , 'brightness' , 255) }}"
brightness: 30
transition: 18000
You have a random ’ on the end of the second wait_template, and you don’t really need the first one, you just need a one second delay to make sure the light is completely on before the next command is executed, but as a belt and braces approach should be fine.
I spotted that one and edited as you was typing
Cool - yeah, give it a punt and let us know if it works
Marc,
This is solved so it’s more of an interlectual exercise now.
12% of 255 is 30.6 (call it 31) and a rise to 255 over 5 hrs (18000 secs) is 1 step every 80s (18000/224) so a full analogue interpretation would reach 255 at the end of 5 hours but 254 at 80.43 secs earlier so a switch point would occur 40.2 secs before end time.
Assuming a full 8bit implementation (255 steps) even when using percent (not sure on that but probable)
Having said all that I won’t lose any sleep over 40 secs in a 5 hour period
I genuinely read my name and then tasted purple. I have no idea whether it works as you say, or whether the final increment is delivered on the final millisecond, but yeah I don’t think 40 seconds will make much difference either way
I have never heard “tasted purple” in my life. But I had fun Googling it !
I will need to google this, but suspect I best not do so at work
No, it’s not rude.
But you should not be cruising the Internet at work anyway, as that’s a breach of trust with your employer
For anyone else who reads this thread and doesn’t watch futurama…
… Or the urban dictionary definition…
https://www.urbandictionary.com/define.php?term=Tasted%20Purple
Both are suitable for work, promise
I get breaks
Still doesn’t work. This is current code, which sets to 30 when executed but does not progress from there:
description: ''
- at: '12:00'
platform: time
condition: []
- data:
brightness: 30
- wait_template: '{{ is_state_attr(''light.0x680ae2fffeb18442_light'' , ''brightness''
, 30) }}'
- data:
brightness: 255
transition: 120
, 255) }}'
- data:
brightness: 30
transition: 120
Any errors in the log?
Also, I don’t know what’s going on with your quotes, but that’s not how we had it a few posts ago.
And there shouldn’t be a new line halfway through the templates either, again not what we had earlier.
I don’t know what on earth is goign on either, I literally copy an pasted it from the earlier post into hassio.
I’ve amended it again and this is now what it looks like:
description: ''
- at: '12:00'
platform: time
condition: []
- data:
brightness: 30
- data:
brightness: 255
transition: 120
- data:
brightness: 30
transition: 120
Still doesn’t work though!
I’ve edited it to the first step and this transitions ok:
description: ''
- at: '12:00'
platform: time
condition: []
- data:
brightness: 255
transition: 180
It seems to this that doesn’t work:
In thsi example, the light does not switch off after 3 minutes:
description: ''
- at: '12:00'
platform: time
condition: []
- data:
brightness: 255
transition: 180
service: light.turn_off
Manually trigger it and then have a look at the logs and see if there is an error.
As an experiment, set the light’s initial brightness to some low value (30) then run the simplified 3-minute example you just posted. I’m curious to see if the light’s starting state influences the first wait_template
(probably not but if we’re poking at this thing, let’s see how it reacts to that).
