This is situation:
I put everything in one file
After reboot:
configuration.yaml
Check configuration:
Sonoff configuration:
Module Config
MQTT config
This is situation:
After reboot:
configuration.yaml
Module Config
MQTT config
Which MQTT server do you have running on 192.168.1.219?
Whatâs in the HA log (the circled i button on bottom right of the menu) and in Tasmota console?
As @namadori suggested three weeks ago - it looks like you do not have a working mosquito broker.
Ignore Home Assistant for now.
First - make sure you have Mosquitto (or whatever broker you have chosen) working at 192.168.1.219 If you do not have a working broker then nothing will work!
mosquitto_sub -u admin -P 12345 -v -t '\''#'\''
)?mosquito_pub
?Second - make sure your Sonoff Basic is publishing to the broker
Third - restart Home Assistant and see if you are still getting errors
PLEASE do not publish screen shots of your configuration.yaml. Use 4 ticks â````â to quote code. See the blue box at the top of this page.
after changing the configuration on the sonoff as shown in the image below:
now everything works! thank you all.
now I have duw sonoff how to configure multiple brokers?
# MQTT
mqtt:
broker: 192.168.1.219
port: 1883
username: admin
password: 12345
# SWITCH
switch:
# SONOFF
- platform: mqtt
state_topic: "stat/sonoff01/POWER"
command_topic: "cmnd/sonoff01/power"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
# optimistic: false
- platform: mqtt
state_topic: "stat/sonoff02/POWER"
command_topic: "cmnd/sonoff02/power"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
# optimistic: false
I give up here. I think you didnât understand what MQTT is and you are not listening to any advice.
absolutely, youâre wrong.
I have rechecked all the settings.
I made a rest of the original configuration.
I started from the beginning as you have advised me all.
the version of my Mosquitto broker 1.0
I left everything and now itâs ok.
Iâm sorry if you think the advice was useless
I thank everyone for their valuable advice.
Enabling the WeMo emulation you are not using MQTT at all.
If you want to make MQTT work:
after you succesfully connect to your broker
after you succesfully connect HA to your broker (if you are on hassio you can see the connection in the Mosquitto add-on log)
youâre right, I do not connect to the mqtt of the sonoff.
I used mqtt spy as recommended by you.
the ip is correct, also correct username and password.
the network has no problem and through the device IP I reach their http interface
OK, I give up.
Why do you ask for advice then ignore it?
The red tab means MQTT Spy canât connect to the broker. We are still at point 1.
