By the way @iPilla , if you pull the curtain to close or open it,
- Does the robot updates its current position?
- Or does that trigger the robot to auto close/open the curtain similar to switchbot/xiaomi smart curtain?
Also, how’s the battery life?
1 no
2 no
2-3 month
I also have these curtains through a gateway and I was able to make them work through the official Tuya integration ( not the V2 ).
Initially it would not work then it magically started to work once I extended the IOT Core Trial subscription.
I assume that was the key because earlier it was always greyed out as mentioned by others, while now it’s consistently connected and responds to open/close/stop commands.
