Mostly I tested it about 10cm from the screen control box. What would be some reasonable distances to test from?
Maybe little more, try 1m
Ok, I got it working!
It turns out I’m not crazy.
The receiver on the esp was not showing the complete signal from the original remote with either tasmota or esphome.
I ended up purchasing an SDR dongle and running rtl_433 to monitor at 315mhz… and the comparison was revelatory! complete bits that I didn’t even know were there!
Once I programmed in the new raw signal, it worked the first try.
#Projector Screen
name: "Projector Screen Stop"
on_press:
- then:
- remote_transmitter.transmit_raw :
transmitter_id: RF_TX
code: [ 200,-600, 200,-600, 600,-200, 200,-600, 600,-200, 200,-600, 200,-600, 200,-600, 200,-600, 600,-200, 200,-600, 200,-600, 600,-200, 600,-200, 200,-600, 600,-200, 200,-600, 200,-600, 200,-600, 200,-600, 600,-200, 200,-600, 200,-600, 200,-600, 200,-600, ]
repeat:
times: 5
wait_time: 6000us
I don’t know if it’s a hardware limitation or something in the rc_switch library, but now I know I can’t necessarily trust the output of the receiver on the esp360
Looks like your setup wasn’t able to recognize 220us high pulse when the previous low pulse was only 160us.
Well done, I tried decoding some 433 mhz signals with ESPHome and like you had to use something else but same receiver. To me ESPHome receiver was more like a random number generator when I tried it, I thought at the time it was fundamentally broken but was just me.
At least you’re sorted.
Andy
Lol I’m right there with you on this.
Hopefully this will help someone else in the future at least.
It would help, if you analyze what was wrong and why…
Absolutely, but I don’t know how to know why the esp receiver was losing bits. I have, at least, provided the information that the problem can exist and a solution that exists. Is it an ideal, perfect solution? no. But I won’t let perfection be the enemy.
Would love to know the cause if someone with more knowledge of the inner workings of the esp or rc_switch library could dig into it!
