Help with advanced switch
Yes, you can.
esphome:
  on_boot:
    priority: 600
    then:
      - lambda: |-
          id(pulse_relay_1).publish_state(id(powerstatus).state);
You could also change the binary_sensor to use the same code, if you want.
binary_sensor:
  - platform: gpio
    pin:
      number: 14
      mode: INPUT_PULLUP
      inverted: True
    on_state:
      then:
        - lambda: |-
Or create a script they both call.
esphome:
  on_boot:
    priority: 600
    then:
      - script.execute: set_heater_switch
binary_sensor:
  - platform: gpio
    pin:
      number: 14
      mode: INPUT_PULLUP
      inverted: True
    on_state:
      then:
script:
  - id: set_heater_switch
    mode: single
    then:
      - lambda: |-
Dang, you’re good at this aye!
