Help with automation trigger when status is 2 minutes old
Try making a template sensor that counts the time since it’s last update. There should be some info in this thread. Relative_time template extension
Once the template sensor works (test it in dev tools) you can create an automation with a template trigger. Something like if state of template sensor is greater than x run action.
Example:
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
    sensors:
      derick_location_for:
        value_template: "{% if states.device_tracker.derick_nexus_6p %}{{(as_timestamp(now())-as_timestamp(states.device_tracker.derick_nexus_6p.last_updated)) // 60 }} Minutes{% else %}??{% endif %}"
      entity_id:
        - sensor.time
#Automation
- alias: trigger after last update reaches a time
platform: template
value_template: “{% if is_state(‘derick_location_for’, ‘2 minutes’) %}true{% endif %}”
service: persistent_notification.create
notification_id: “1234”
message: “Sensor is Down”
title: “Test”
