mgim
April 29, 2021, 10:55pm
21
Hi guys,
I would also need a bit of help with this card.
I intend to use it with the apexcharts card in the graph_span attribute. The thing is that this card is expecting something like 10d or 5h. But my variable is an input_number so it does not work (yet).
Any clue how to solve this?
- type: 'custom:config-template-card'
variables:
NB_JOURS: 'states[''input_number.nb_jours_elec''].state'
entities:
- input_number.nb_jours_elec
card:
type: 'custom:apexcharts-card'
graph_span: '${NB_JOURS}'
I am using the custom:config-template-card for this card
type: entities
title: Status & Information
entities:
- entity: vacuum.dreamed9
icon: mdi:robot-vacuum
tap_action: null
action: more-info
- type: custom:template-entity-row
name: Water Container
state: >-
{% if is_state_attr('vacuum.dreamed9', 'waterbox','removed')%} Removed {%
else %} Present {% endif %}
icon: mdi:watering-can
tap_action: none
- type: conditional
conditions:
- entity: binary_sensor.d9_active
state: 'on'
tap_action: none
row:
type: attribute
attribute: cleaning_area
suffix: m²
- type: conditional
conditions:
state: 'on'
tap_action: none
row:
icon: mdi:timer-outline
type: attribute
attribute: cleaning_time
suffix: m
icon: mdi:ruler-square
type: attribute
name: Total Cleaned Area
attribute: total_cleaning_area
suffix: m²
tap_action: none
- type: custom:config-template-card
variables:
- states['vacuum.dreamed9']
entities:
- ${vars[0].entity_id}
card:
type: entities
entities:
- type: custom:bar-card
attribute: filter_life_percent
icon: mdi:air-filter
unit_of_measurement: ' %'
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
name: ${ "Filter - " + vars[0].attributes['filter_time_left']+" h"}
attribute: main_brush_life_percent
icon: mdi:car-defrost-front
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
${ "Main Brush - " + vars[0].attributes['main_brush_time_left']+"
h"}
attribute: side_brush_life_percent
icon: mdi:fan
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
${ "Main Brush - " + vars[0].attributes['side_brush_time_left']+"
h"}
Is there any way I can extract/generalize this part
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
So I don’t have to repeat myself and only have to call a kind of own template with two parameters for
and
so that it looks like something like that
type: entities
entities:
tap_action: null
action: more-info
state: >-
tap_action: none
- type: conditional
conditions:
state: 'on'
tap_action: none
row:
type: attribute
suffix: m²
- type: conditional
conditions:
state: 'on'
tap_action: none
row:
type: attribute
suffix: m
type: attribute
suffix: m²
tap_action: none
variables:
entities:
card:
type: entities
entities:
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
h"}
icon: mdi:fan
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
h"}
attribute: <param1>
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
name: ${ <label> + " - " + <param2> +" h"}
Thank you!
petro
(Petro)
April 26, 2022, 11:28am
23
Yes. You can use anchors but they need to be in the same file.
declaring it
<<: &my_bar_card
width: 55%
height: 2em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
using it later…
<<: *my_bar_card
will try that!
and how can pass/define the value for name:
Thank you!
petro
(Petro)
April 26, 2022, 2:43pm
25
You can’t pass values to anchors. You have to exclude the fields from the anchor and supply them separately, like I did in the example above.
Thank you! Will try that.
Hi @petro ,
that worked perfectly! Thank you!
In any case someone wants know, here the reworked config of my card
type: entities
entities:
tap_action: null
action: more-info
state: >-
tap_action: none
- type: conditional
conditions:
state: 'on'
tap_action: none
row:
type: attribute
suffix: m²
- type: conditional
conditions:
state: 'on'
tap_action: none
row:
type: attribute
suffix: m
type: attribute
suffix: m²
tap_action: none
variables:
entities:
card:
type: entities
entities:
<<: &my_bar_card
width: 55%
height: 2.1em
decimal: 0
positions:
icon: outside
indicator: 'off'
severity:
- color: Red
to: 33
- color: Orange
to: 66
- color: Green
to: 100
h"}
<<: *my_bar_card
icon: mdi:fan
${ "Side Brush - " + vars[0].attributes['side_brush_time_left']+"
h"}
<<: *my_bar_card
