Hi Petro,
I finally solved the problem. Thanks to you, I used the following code you provided in the previous post, to query the state of variable ‘light_id’ (instead of entity_id). And it works!
My script now:
dimmer_swipe_up: sequence: - service: light.turn_on data_template: entity_id: '{{ light_id }}' brightness: >- {% set domain, name = light_id.split('.') %} {% set current = states[domain][name].attributes.brightness | int %} {% set step = states('input_number.light_step') | int %} {% set next = current + step | int %} {% if next > states('input_number.light_maximum') | int %} {% set next = states('input_number.light_maximum') | int %} {% endif %} {{ next }}
So the variable got passed alright. The caveat was how I queried the state of the variable. It seems your approach works for me! Thank you so much!
