MINI-GRAPH-CARD 0.10.0
utils.ts:3 BATTERY-STATE-CARD 1.6.2
auto-entities.js:2 AUTO-ENTITIES 1.7.0 IS INSTALLED
card-tools.js:90 CARD-TOOLS 2.1.2 IS INSTALLED DeviceID: ed666fa9-ee57ddef
canary.js:1 CANARY 0.3.1
card-mod.js:5 CARD-MOD 2.0.3 IS INSTALLED
fold-entity-row.js:46 FOLD-ENTITY-ROW 19.0.0 IS INSTALLED
slider-entity-row.js:68 SLIDER-ENTITY-ROW 1.0.0 IS INSTALLED
time-picker-card.js:430 TIME-PICKER-CARD Version 1.1.1
config-template-card.js:3254 CONFIG-TEMPLATE-CARD Version 1.3.0
harmony-card.js:445 HARMONY-CARD Version 0.14.0
mini-climate-card-bundle.js:1 MINI-CLIMATE-CARD v1.2.7
light-entity-card.js:9160 LIGHT-ENTITY-CARD Version 4.2.2
template-entity-row.js:32 TEMPLATE-ENTITY-ROW 1.1.1 IS INSTALLED
entities.js:28 SPOTIFY-CARD Version 2.3.6
multiple-entity-row.js:1 MULTIPLE-ENTITY-ROW 4.1.1
card.js:219
RGB Light Card v1.7.1
scheduler-card.js:1626 SCHEDULER-CARD Version: v2.0.4
vertical-stack-in-card.js:1 vertical-stack-in-cardVersion: 0.4.0
hui-element.js:1 HUI-ELEMENT 1.0.1 IS INSTALLED
numberbox-card.js:3 NUMBERBOX_CARD 1.8
lovelace-card-templater.js:8 CARD-TEMPLATER Version 0.0.9
VM5163 test:1 Autofocus processing was blocked because a document already has a focused element.
2chunk.455e79b014618741a716.js:2837 card sensor Error: Specify an entity from within the sensor domain
at HTMLElement.value (chunk.9d6cfa32196f20fd6f2e.js:3400)
at s (chunk.455e79b014618741a716.js:2837)
at d (chunk.455e79b014618741a716.js:2837)
at c (chunk.455e79b014618741a716.js:2837)
at a (chunk.455e79b014618741a716.js:2837)
at HTMLElement.value (chunk.9d6cfa32196f20fd6f2e.js:3702)
at chunk.9d6cfa32196f20fd6f2e.js:3400
at Array.map ()
at HTMLElement.value (chunk.72df0e2934b88fac4ebc.js:1)
c @ chunk.455e79b014618741a716.js:2837
VM5163 test:3 Uncaught (in promise) SyntaxError: Illegal return statement
at HTMLElement._evaluateTemplate (config-template-card.js:3401)
at config-template-card.js:3349
at Array.forEach ()
at HTMLElement._evaluateConfig (config-template-card.js:3338)
at HTMLElement._evaluateArray (config-template-card.js:3363)
at config-template-card.js:3343
at Array.forEach ()
at HTMLElement.render (config-template-card.js:3313)
at HTMLElement.update (config-template-card.js:3179)
at Array.map ()
at Array.forEach ()
at Array.forEach ()
at Array.map ()
at Array.forEach ()
at Array.forEach ()
at Array.map ()
at Array.forEach ()
at Array.forEach ()
at Array.map ()
at Array.forEach ()
at Array.forEach ()
at Array.map ()
at Array.forEach ()
at Array.forEach ()
at Array.map ()
at Array.forEach ()
at Array.forEach ()
at Array.map ()
2VM5163 test:3 Uncaught (in promise) SyntaxError: Illegal return statement
at Array.forEach ()
at Array.forEach ()
VM5163 test:1 Uncaught (in promise) SyntaxError: Illegal return statement
at HTMLElement._evaluateArray (config-template-card.js:3366)
at Array.forEach ()
at HTMLElement.performUpdate (config-template-card.js:2416)
at HTMLElement._enqueueUpdate (config-template-card.js:2369)
_evaluateTemplate @ config-template-card.js:3401
_evaluateArray @ config-template-card.js:3366
(anonymous) @ config-template-card.js:3343
_evaluateConfig @ config-template-card.js:3338
render @ config-template-card.js:3313
update @ config-template-card.js:3179
performUpdate @ config-template-card.js:2416
_enqueueUpdate @ config-template-card.js:2369
testing:3 Uncaught (in promise) SyntaxError: Illegal return statement
at Array.forEach ()
at Array.forEach ()
VM5664:3 Uncaught (in promise) SyntaxError: Illegal return statement
at Array.forEach ()
at Array.forEach ()
Is there any way you can help me. I have a bunch of chromecasts and would ove to be able to switch between them.
I created a select template with the values of my remotes.
