Use the code format, 3 backticks:
like this
not the quote format
like this
Is that the whole log? It looks like there should be some more logs around that.
like this
like this
Sorry.
This was just the error visible in frontend.
Below full log:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/deconz/light.py:203
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 9:33:27 (4 occurrences)
Last logged: 9:33:45
[140412949250400] /lights/10/state parameter, hue, not available
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 136, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1455, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1490, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 595, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 664, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 632, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 233, in async_handle_light_on_service
await light.async_turn_on(**params)
File "/usr/src/homeassistant/homeassistant/components/group/light.py", line 238, in async_turn_on
await self.hass.services.async_call(
task.result()
await coro
await result
File "/usr/src/homeassistant/homeassistant/components/template/light.py", line 350, in async_turn_on
await self._on_script.async_run(context=self._context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1033, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 246, in async_run
await self._async_step(log_exceptions=False)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 254, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 464, in _async_call_service_step
await service_task
task.result()
await coro
await result
File "/usr/src/homeassistant/homeassistant/components/deconz/light.py", line 203, in async_turn_on
await self._device.async_set_state(data)
File "/usr/local/lib/python3.8/site-packages/pydeconz/deconzdevice.py", line 38, in async_set_state
await self.async_set(field, data)
File "/usr/local/lib/python3.8/site-packages/pydeconz/api.py", line 118, in async_set
await self._request("put", field, json=data)
File "/usr/local/lib/python3.8/site-packages/pydeconz/gateway.py", line 109, in request
_raise_on_error(response)
File "/usr/local/lib/python3.8/site-packages/pydeconz/gateway.py", line 225, in _raise_on_error
raise_error(data["error"])
File "/usr/local/lib/python3.8/site-packages/pydeconz/errors.py", line 58, in raise_error
raise cls("{} {}".format(error["address"], error["description"]))
pydeconz.errors.RequestError: /lights/10/state parameter, hue, not available
UP.
I updated to latest version and still can’t be able to use template light to combine 2 different entities.
I still need support.
Thank you
Were you ever able to solve it?
