There are two solutions that I could figure out:
1.In Domoticz: place the sensor in a floorplan, set mqtt topic to “/” (basically have a separate topic for the sensor; haven’t checked if multiple floorplans could be set, so each sensor has its own). Then in HA the sensor would be:
- platform: mqtt
state_topic: 'domoticz/out/name/floorplan'
unit_of_measurement: '°C'
value_template: '{{ value_json.svalue1 }}'
- platform: mqtt
unit_of_measurement: '%'
value_template: '{{ value_json.svalue2 }}'
Use flat (“out”) or flat + hierarchical ( “out + /” if needed to combine with first option above) topic for mqtt in Domoticz and set an automation that would read each sensor (no need for floorplan).
#automation - based on the payload in the first message. If weather station has only temperature readings lose the second sensor.- alias: WS1 initial_state: True trigger: - platform: mqtt topic: 'domoticz/out' condition: condition: template value_template: '{{ "82019" in trigger.payload }}' action: - service: mqtt.publish data_template: topic: "home/weatherstation1/temp" payload_template: '{{ trigger.payload_json.svalue1 }}' - service: mqtt.publish data_template: topic: "home/weatherstation1/hum" payload_template: '{{ trigger.payload_json.svalue2 }}'
#Sensors
- platform: mqtt
state_topic: 'home/weatherstation1/temp'
- platform: mqtt
state_topic: 'home/weatherstation1/hum'
