Help with multiple conditions using or
What is the error?
Hi ‘finity’ … the same error for the guy/gal who started this thread …
Unsupported condition: or
Not sure whether you can confirm it or not, I have not confirmed it yet through trial and error, but I found another thread where apparently the belief was that even though you get this error, specifically in the ‘new’ automation GUI of Hassio, the YAML code in your automations.yaml file should still work as expected.
That’s what I am going with at this moment.
Ah, Ok. this thread is over 2 years old and there was at least two different errors being discussed so i wasn’t sure which error you were referring to.
But yes, as of right now (as far as I know…) the automation editor in the UI doesn’t support the “or” condition structure.
you have to do that the old fashioned (but better…:wink:) way and manually type it in.
So, if you type it in manually the code you have works OK?
I hope so … though if you mean does the yaml code seem to pass validation in my automations.yaml file in an editor … I think so/assume so … I haven’t checked though.
I also cannot confirm yet if the or condition in my automation works or not in real life.
