Help with simple ADC samples on ESPHOME YAML [samples] is an invalid option for [sensor.adc]
Hi everyone,
I’m having some problems with the ADC component. I’m using an Wemos ESP32-S2 mini (That with the purple board):
And I want to set up sampling on three ADC sensors, for GPIO7, 8 and 9. When I configure the ADC component by default (1 sample), it compiles without a problem. But when I add the "samples: " entry, it refuses to compile.
This is the yaml that compiles (Note that I cannot add the “samples” entry):
esphome:
  friendly_name: nevera
esp32:
  board: esp32-s2-saola-1
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "+-----="
ota:
  password: "-------"
wifi:
  networks:
  - ssid: !secret wifi_ssid3
    password: !secret wifi_password3
  manual_ip:
    static_ip: 192.168.1.19
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    dns1: 192.168.1.1
    dns2: 8.8.4.4
  ap:
    ssid: "Nevera Fallback Hotspot"
    password: "----------"
captive_portal:
web_server:
  port: 80
text_sensor:
  - platform: wifi_info
    ip_address:
    ssid:
      name: Nome da rede
    scan_results:
      name: Redes Dispoñibles
  - platform: adc
    pin: GPIO7
    attenuation: 11db
    update_interval: 1s
  - platform: adc
    pin: GPIO8
    update_interval: 1s
    attenuation: 11db
  - platform: adc
    pin: GPIO9
    update_interval: 1s
    attenuation: 11db #Segun a web de espresif, desde 0 a 2500 mV
Notes:
  • I use GPIO7, 8 and 9 because the recomended 32-39 raises an error:
    imaxe
    The documentation lets me use this pins on an ESP32-S2, with the ADC1:
    Analog To Digital Sensor — ESPHome
  • This is what I get when I write the “samples” entry:
  • I have also read that if I am using auto gain, samples are ignored. But I am setting the gain to a value, so this should not be the problem. Or am I missynderstanging something?
  • I unploaded screenshots of the error because I don’t know if it makes sense to upload a faulty code, does it?
    Thank your everyone for your help!
Difficult to follow…
Ok, your pins should be ok, 32-39 are not adc pins on your board.
On your yaml I don’t see line “samples: 10”, but in your error there is…
Have you tried some other boar definition ?
ps. when prototyping, use wroom 32 board. After everything works, try to adapt for “weird” boards if you need to.
Hi @Karosm
Thank you a lot for reading!.
Sorry for that. I edited the post a little, I hope it helps.
Yes. I uploaded the code that compiles. Should have I posted the code that gives me an errror? If so, I will post it.
Nope, I didn’t know that I could change the boards. I will try with the Wroom32 as you suggest.
Thank you again!
EDIT:
I tried to change the board definition. When I set the board name to “nodemcu-32s” (The wroom 32 as mencioned here:
And I can’t compile, because GPIO definition is different. So I tried with the “lolin_s2_mini” as suggested here:
And I get the same error.
If it helps, here is the faulty code (with the new board definition):
esphome:
esp32:
  board: lolin_s2_mini
  framework:
    type: arduino
# Enable logging
logger:
api:
  encryption:
    key:
ota:
  password:
wifi:
  networks:
  - ssid: !secret wifi_ssid2
    password: !secret wifi_password2
    # O 3 é Cacharrada
  manual_ip:
    dns1: 192.168.1.1
    dns2: 8.8.4.4
  ap:
    password: "7DXF1upJDny3"
captive_portal:
web_server:
  port: 80
text_sensor:
    ip_address:
    ssid:
      name: Nome da rede
    scan_results:
  - platform: adc
    pin: GPIO7
    attenuation: 11db
    update_interval: 1s
    samples: 10 ##### HERE IS THE PROBLEM#####
  - platform: adc
    pin: GPIO8
    update_interval: 1s
    attenuation: 11db
  - platform: adc
    pin: GPIO9
    update_interval: 1s
Thanks!
Board looks good
Gpios look good
Still the same “samples is an invalid option” error?
Yes, it still has the error:
Hi
I got rid of this using one ads1115
If you need accurate values, I recomend this.
I just tried it on an ESP32-C3 and got no errors, but as I do not have an ESP32-S2, the following might be the reason:
Support for ESP32 variants such as the S2, S3 and C3 is still in development and there could be issues.
I recommend opening an issue here: Issues · esphome/issues · GitHub
