Help with statistics sensor
No they don’t. Reload core will reload anything in the homeassistant section for example. Stats should get reloaded if you reload sensors. It can be a bit unreliable but generally works ok. I use the reload functions a lot and if something doesnt reload I then restart HA.
The thing is, it did load, at least it appeared to. I added the sensor and it appeared as an entity. It just didn’t receive any updates until I did a full restart
