no it allowed templating. On that is, or True.
Cant get it away anymore, using either:
{“object_id”:“developer”, “view”:“false”, “visible”:"false " } or
{“object_id”:“developer”, “view”:"{{ is_state(‘input_select.mode’, ‘Developer’) }}", “visible”:"{{ is_state(‘input_select.mode’, ‘Developer’) }} " }
hmm, seems it only accepts, true or True…
Invalid service data for group.set: invalid boolean value false for dictionary value @ data['visible']. Got 'False '
Forget what i said about only accepting true. It didnt accept " False", or " False ". Spaces…
tried a binary_sensor:
{“object_id”:“developer”, “view”:"{{is_state(‘binary_sensor.mode_developer’,‘on’)}}", “visible”:"{{is_state(‘binary_sensor.mode_developer’,‘on’)}}"}
no such luck.
Guess is was the templating after all… such a pity, only half the support we want…
filed a feature request at:
workaround for the time being:
## Switch
switch:
switches:
mode_developer:
friendly_name: Developer mode switch
value_template: >
{{ is_state('input_select.mode', 'Developer') }}
turn_on:
- service: script.mode_developer_direct
- service: homeassistant.turn_on
entity_id: input_boolean.notify_developing
- service: group.set
object_id: developer
view: true
visible: true
turn_off:
- service: script.mode_normal_direct
- service: homeassistant.turn_off
view: false
visible: false
or, even better maybe per Mode:
scene_developer:
alias: Call Developer scene
sequence:
entity_id: group.philips_motion_sensor_switches
- service: input_select.select_option
entity_id: input_select.theme
option: 'matrix'
view: true
visible: true
anyways, hoping for the templating option…
