Yes. You have to copy xiaomi_miio.py ti tour /config/custom_components/vacuum/ folder and restare HA
That’s what I did, but it gave an error. Can you view the automation code?
Check your config with my pagkage:
Thank you. I’ll check later, I’m at work
Ok, I took the code and rebuilt (including translation) for my convenience - a picture attached. I try to figure out how to operate the robot to access the area - for example the kitchen
I get the following error I go into to select my zone
## Log Details (WARNING)
Not passing an entity ID to a service to target all entities is deprecated. Use instead: entity_id: "all"
He does not find the vacuum.xiaomi_clean_zone. I added your py file here:
Here is my code:
You’ll find everything in my github
same problem how to fix it?
which problem? could you explain it?
Same problem like what abeksis write:
Look at all files on github abeksis please.
after copy xiaomi_miio.py in custom_components/vacuum folder, have you restarted HA?
Try to start service with http://yourip:8123/dev-service
you must set parameters like this:
“entity_id”: “vacuum.xiaomi_vacuum”,
“repeats”:2,
“zone”:[[30914,26007,35514,28807],[20232,22496,26032,26496]]
That’s what I did - you can see here
you must use straight unformatted quotes…
"entity_id" : "vacuum.vacuum",
"repeats" : "2",
"zone": [[23759,28427,28559,31677]]
sorry, no quotes in parameters zone and put your entity_id…
