Until a ‘Subtract Two Sensors’ Helper is implemented (if ever) here’s how to do it with a simple Template Sensor.
In the following example, the goal is to subtract the value of sensor.subtrahend from the value of sensor.minuend and report the result in sensor.difference.
template:
- sensor:
- name: Difference
state: "{{ states('sensor.minuend') | float(0) - states('sensor.subtrahend') | float(0) }}"
How the template works:
states('sensor.minuend')gets thestatevalue ofsensor.minuend. - State values are always strings (text) even when they appear to be numeric. We convert the string value to a floating point number (a number with decimal places as opposed to integer) using
float(0). - The
0infloat(0)is a chosen default value. Iffloatis unable to convert the sensor’sstatevalue it will report0(the default value). You can set the default value to whatever is best for your application. For example, if the sensor’s value isunavailablethenfloatwill report0. - The second half of the template simply performs the same procedure for
sensor.subtrahendand then subtracts the resulting value from the value ofsensor.minuend.
