Well then I guess it make sense to wait. Especially because of PoE…
Thanks!
Just to be on the safe side.
The android monitor, also works with the station below right?
DS-KV6113-WPE1
I ask because the android monitor on Hikvision website, appears only the pro lineup products.
dont buy it yet the 93xx/95xx series
they are slow, low specs, run on android 5 , impossible to run .apk files
there will be a new version/revision this year
How do you know there will be a new version?
my reseller told me, and someone from hikvision benelux , normally around november/december
better specs, and it will run on android 10 or 11
Ok, But then the android monitor also works with other stations outside the pro lineup, right?
no idea, i have the ds-kd8003
I was wondering if somebody has already succeeded to capture the button press event for the Hikvision DS-KV6113-WPE1?
The Hikvision DS-KV6113-WPE1 seems to have all the functionality I need except the ‘easy’ integration into home assistant, so it would be really cool if this feature would become available in HA.
Thanks!
have a look here, not sure if your device supports isapi or sdk
alternative you can use the cloud:
Hi
What Doorbell model do you use?
I just want to purchase kv6113-pe1 but I’m not sure if have some integration to HA?
I need when someone trigger the doorbell button get some notifications on HA and of course take still image and show me it on HA
Kv6113-pe1 model can fit that mission?
Hi
Did you found how integrated?
I have this model (DS-KV6113-WPE1), I managed to get it to send me a notification with a snapshot when someone calls. In addition, it saves a 30sec video short. But as far as I know this model is EOL, so I would recommend you go for the model with DS-KV6113-WPE1 (B).
Hi sorry @henaa i missed your question before. I purchased this setup. A little pricey though but ive been incredibly happy for the last year it hasnt skipped a beat since install. These prices are AUD.
The setup ticks all my boxes.
But note - i never solved the ‘fire event into hass on doorbell press’ as i never needed to. I solved in another way - virtual line crossing on another hikvision cam that fires when someone walking uo my pathway, snapshots to telegram from multiple angles. Works so well.
You have maybe all the steps or guide you doing the integration?
Hi Virgil, I have exactly the same model. Could you be so kind and share your configuration? Thanks!
sure
camera:
- platform: ffmpeg
input: "rtsp://admin:[email protected]:554/ch1/main/av_stream"
And automation:
alias: Interfon - Camera Snapshot
description: ''
- platform: state
entity_id: sensor.interfon_status
to: ring
- service: camera.snapshot
filename: /config/www/interfon/interfon_{{ now().strftime("%Y%m%d-%H%M") }}.jpg
entity_id: camera.interfon
- service: notify.mobile_app_mdv
title: Interfon
message: Camera
image: >-
https://ip/local/interfon/interfon_{{
- service: camera.record
duration: 30
filename: /config/www/interfon/interfon_{{ now().strftime("%Y%m%d-%H%M") }}.mp4
- service: persistent_notification.create
title: Interfon {{ now().strftime("%m.%d-%H:%M") }}
message: >-
Camera .strftime("%Y%m%d-%H%M") }}.jpg)
mode: single
check my last post.
Thank you very much for you answer Virgil. I have something really close for the snapshots and so far I’m not yet recording.
About the camera I was not aware of this url:
And I’m using this instead without knowing if there are differences between both ( My FW is the 2.1.5 and I’ve noticed that is available the 2.1.35 for the non (B) versions but I didn’t upgrade yet.
rtsp://admin:[email protected]:554/Streaming/Channels/101
Finally a question about how are you updating the sensor.interfon_status? I’m using the rest sensor and polling every 2 seconds but sometimes the snapshot taken is already too late.
- platform: rest
authentication: digest
username: admin
password: password
scan_interval: 2
resource: http://192.168.1.xxx/ISAPI/VideoIntercom/callStatus?format=json
value_template: '{{ value_json.CallStatus.status }}'
Thanks again.
I have the DS-HD1 powered off the chime and have done nothing to integrate it to HA beyond the HACS integration which successfully authenticates but does not surface any entities for this model yet. Not sure if anyone has mentioned playing around with that one yet. My thought process in selecting it was, “not a Ring? Buy it”
