Here is one that I use with my ESP32 C3 Mini 1 boards. It is based on the YAML from Screek for their 2A sensors.
just got my ld2450 from Ali.
Honestly, it seems to throw totally random numbers ![]()
it came with version 2.04.23101915, but i also tried downgrading to 1.2.23051810 and it seems to behave the same
am i missing something?
firmware 2 seems also to have enabled the reporting of serial data over BLE, so can we avoid ESP-Home or a dedicated device to read from it? However, i canāt figure out how to connect it to HA⦠any hint?
I donāt believe there is currently a direct bluetooth integration available in HA for the LD2450. For those using the LD2450 in Home Assistant would be by conecting the TX/RX pins it to an ESP board.
i see thereās a BLE integration for the 2410, maybe it is somehow similar, iāll try to give a lookā¦
the device publishes a service UUID where data is available in the same format it has on the serial interface, so it should be readableā¦
however, no idea how to change settings (for example, single target vs multi target)
The LD2410 discloses the high-level protocol, while the BLE portion of the LD2450 is not currently disclosed and may have to be reversed over.
From a batch of LD2450ās we just DIYād, the numbers are off if the radar is mounted at the right height, but it doesnāt seem to be some sort of random number.
just to check if i got you right, LD2450 broadcasts on BT the same datagram it sends on serial, but this is not āofficialā so we are assuming it can change?
Oh well, it makes sense ![]()
i saw the LD2410 BLE code and it seems quite hard to adapt (datagram is totally different!) so probably you are right and it is not a good investment to create code until it is officialā¦
I think their mechanisms may be the same (we have not evaluated their communication data, nor have we grabbed packets), and of course we would love to have HLK publish these protocol codes in the future. After that, it will still take open source enthusiasts to complete an integration plugin. That seems a bit far away.
At the moment I think the WIFI approach is satisfactory, we share more than 1300 2Aās around the world (exhausting to make, but quite fun) and most of them work well.
After having great experience with LD2410 decide to try the LD2450.
Have an issue I need help with despite the rather smooth setup. āAny Presenceā shows detected but all of the zone presence show clear even when Iām in the zone.
Using the HLK android tool, zone I created there is not reflected in HA, so I manually created another set of zones in HA. Now it seems I have two different set of zones, one in HLK app and one in HA.
I believe Iām using the yaml shared by athua which is based on the screek 2A.
Kit
- 30pin esp32 cp2012
- LD2450
friendly_name: ESP32-CP2012
espID: esphome_web_xxxxxx
esphome:
friendly_name: ${friendly_name}
on_boot:
- priority: 100
then:
lambda: |-
id(cpu_speed) = ESP.getCpuFreqMHz();
- priority: -200
then:
lambda: |-
id(zone1_target_exsits).publish_state(false);
id(zone2_target_exsits).publish_state(false);
id(zone3_target_exsits).publish_state(false);
id(zone_ex1_target_exsits).publish_state(false);
esp32:
board: esp32dev
framework:
type: arduino
debug:
update_interval: 30s
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
ota:
esp32_ble_tracker:
scan_parameters:
active: true
bluetooth_proxy:
active: true
wifi:
networks:
- ssid: !secret wifi2_ssid
password: !secret wifi2_password
priority: 2
- ssid: !secret wifi_ssid
priority: 1
ap:
ssid: ${name}
password: "xxxxxxxxx"
captive_portal:
preferences:
flash_write_interval: 5s
globals:
- id: cpu_speed
type: int
restore_value: no
initial_value: '0'
- id: last_update_ld2450
type: unsigned long
restore_value: no
initial_value: '0'
- id: init_zone_publish
type: bool
restore_value: no
initial_value: "false"
text_sensor:
- platform: debug
reset_reason:
name: "ESP Reset Reason"
icon: mdi:anchor
disabled_by_default: True
- platform: wifi_info
ip_address:
name: ESP IP Address
entity_category: "diagnostic"
icon: mdi:ip-network
mac_address:
icon: mdi:information-outline
entity_category: config
lambda: |-
return {"Configure below" };
update_interval: 1000s
lambda: |-
lambda: |-
lambda: |-
return {"Zone Exclusion 1" };
number:
name: "Any Presence Timeout"
min_value: 0
max_value: 600
mode: box
device_class: duration
unit_of_measurement: s
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
min_value: 0
max_value: 600
mode: box
icon: mdi:timer-off
step: 1
optimistic: True
initial_value: 0
restore_value: True
# Zone 1
min_value: -4000
max_value: 4000
mode: box
device_class: distance
unit_of_measurement: mm
icon: mdi:arrow-left-bold
step: 10
optimistic: True
initial_value: 0
restore_value: True
on_value:
then:
- script.execute: check_zone1_vaild
mode: box
min_value: -4000
max_value: 4000
icon: mdi:arrow-right-bold
step: 10
initial_value: 0
optimistic: True
restore_value: True
on_value:
then:
mode: box
min_value: 0
max_value: 6000
icon: mdi:arrow-up-bold
step: 10
initial_value: 0
optimistic: True
restore_value: True
on_value:
then:
icon: mdi:arrow-down-bold
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
on_value:
then:
# Zone 2
min_value: -4000
max_value: 4000
mode: box
step: 10
optimistic: True
initial_value: 0
restore_value: True
on_value:
then:
- script.execute: check_zone2_vaild
mode: box
min_value: -4000
max_value: 4000
step: 10
initial_value: 0
optimistic: True
restore_value: True
on_value:
then:
mode: box
min_value: 0
max_value: 6000
step: 10
initial_value: 0
optimistic: True
restore_value: True
on_value:
then:
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
on_value:
then:
# Zone 3
min_value: -4000
max_value: 4000
mode: box
step: 10
optimistic: True
initial_value: 0
restore_value: True
on_value:
then:
- script.execute: check_zone3_vaild
mode: box
min_value: -4000
max_value: 4000
step: 10
initial_value: 0
optimistic: True
restore_value: True
on_value:
then:
mode: box
min_value: 0
max_value: 6000
step: 10
initial_value: 0
optimistic: True
restore_value: True
on_value:
then:
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
on_value:
then:
# Zout1
min_value: -4000
max_value: 4000
mode: box
step: 10
optimistic: True
initial_value: 0
restore_value: True
on_value:
then:
- script.execute: check_zout1_vaild
mode: box
min_value: -4000
max_value: 4000
step: 10
initial_value: 0
optimistic: True
restore_value: True
on_value:
then:
mode: box
min_value: 0
max_value: 6000
step: 10
initial_value: 0
optimistic: True
restore_value: True
on_value:
then:
mode: box
min_value: 0
max_value: 6000
initial_value: 0
step: 10
optimistic: True
restore_value: True
on_value:
then:
binary_sensor:
- platform: status
name: "Any Presence"
device_class: occupancy
filters:
- delayed_off: !lambda |-
return id(any_presence_timeout).state * 1000.0;
name: "Zone1 Presence"
filters:
return id(zone1_x_timeout).state * 1000.0;
name: "Zone2 Presence"
filters:
return id(zone2_x_timeout).state * 1000.0;
name: "Zone3 Presence"
filters:
return id(zone3_x_timeout).state * 1000.0;
name: "Zout1 Presence"
icon: mdi:account-multiple-remove
script:
- id: check_zone1_vaild
then:
- lambda: |-
if (id(zone1_x_begin).state > id(zone1_x_end).state){
id(tips_zone1_conf).publish_state("Err: X-Begin > X-End");
return;
if (id(zone1_y_begin).state > id(zone1_y_end).state){
id(tips_zone1_conf).publish_state("Err: Y-Begin > Y-End");
return;
if (id(zone1_x_begin).state == 0, id(zone1_x_end).state == 0, id(zone1_y_begin).state == 0, id(zone1_y_end).state == 0){
id(tips_zone1_conf).publish_state("Configure below");
return;
int x_size = id(zone1_x_end).state - id(zone1_x_begin).state;
int y_size = id(zone1_y_end).state - id(zone1_y_begin).state;
char combined[80];
sprintf(combined, "Curr Size: %d x %d", x_size, y_size);
id(tips_zone1_conf).publish_state(combined);
- id: check_zone2_vaild
then:
- lambda: |-
if (id(zone2_x_begin).state > id(zone2_x_end).state){
id(tips_zone2_conf).publish_state("Err: X-Begin > X-End");
return;
if (id(zone2_y_begin).state > id(zone2_y_end).state){
id(tips_zone2_conf).publish_state("Err: Y-Begin > Y-End");
return;
if (id(zone2_x_begin).state == 0, id(zone2_x_end).state == 0, id(zone2_y_begin).state == 0, id(zone2_y_end).state == 0){
id(tips_zone2_conf).publish_state("Configure below");
return;
int x_size = id(zone2_x_end).state - id(zone2_x_begin).state;
int y_size = id(zone2_y_end).state - id(zone2_y_begin).state;
char combined[80];
id(tips_zone2_conf).publish_state(combined);
- id: check_zone3_vaild
then:
- lambda: |-
if (id(zone3_x_begin).state > id(zone3_x_end).state){
id(tips_zone3_conf).publish_state("Err: X-Begin > X-End");
return;
if (id(zone3_y_begin).state > id(zone3_y_end).state){
id(tips_zone3_conf).publish_state("Err: Y-Begin > Y-End");
return;
if (id(zone3_x_begin).state == 0, id(zone3_x_end).state == 0, id(zone3_y_begin).state == 0, id(zone3_y_end).state == 0){
id(tips_zone3_conf).publish_state("Configure below");
return;
int x_size = id(zone3_x_end).state - id(zone3_x_begin).state;
int y_size = id(zone3_y_end).state - id(zone3_y_begin).state;
char combined[80];
id(tips_zone3_conf).publish_state(combined);
- id: check_zout1_vaild
then:
- lambda: |-
if (id(zone_ex1_x_begin).state > id(zone_ex1_x_end).state){
id(tips_zone_ex1_conf).publish_state("Err: X-Begin > X-End");
return;
if (id(zone_ex1_y_begin).state > id(zone_ex1_y_end).state){
id(tips_zone_ex1_conf).publish_state("Err: Y-Begin > Y-End");
return;
id(tips_zone_ex1_conf).publish_state("Zone Exclusion 1");
name: "ESP CPU Speed"
accuracy_decimals: 0
icon: mdi:cpu-32-bit
unit_of_measurement: Mhz
lambda: |-
return (id(cpu_speed));
update_interval: 600s
name: ESP Temperature
lambda: return temperatureRead();
unit_of_measurement: °C
device_class: TEMPERATURE
update_interval: 45s
- platform: uptime
update_interval: 60s
- platform: wifi_signal
icon: mdi:memory
name: ESP Free Memory
lambda: return heap_caps_get_free_size(MALLOC_CAP_INTERNAL) / 1024;
unit_of_measurement: 'kB'
state_class: measurement
# é«ēŗ§é·č¾¾ę°ę®
name: "All Target Counts"
icon: "mdi:counter"
unit_of_measurement: "targets"
name: "Zone1 Target Counts"
icon: "mdi:counter"
name: "Zone2 Target Counts"
icon: "mdi:counter"
name: "Zone3 Target Counts"
icon: "mdi:counter"
name: "Zout1 Target Counts"
icon: mdi:account-multiple-minus-outline
# Target 1
unit_of_measurement: 'mm'
accuracy_decimals: 2
unit_of_measurement: 'm/s'
device_class: speed
name: "Target1 Resolution"
# Target 2
device_class: speed
name: "Target2 Resolution"
# Target 3
device_class: speed
name: "Target3 Resolution"
time:
- platform: sntp
switch:
- platform: factory_reset
icon: mdi:heart-broken
optimistic: True
icon: mdi:account-cancel
restore_mode: RESTORE_DEFAULT_OFF
button:
- platform: restart
icon: mdi:power-cycle
entity_category: diagnostic
uart:
tx_pin:
number: GPIO17
mode:
input: true
pullup: true
rx_pin:
number: GPIO16
mode:
input: true
pullup: true
baud_rate: 256000
parity: NONE
stop_bits: 1
data_bits: 8
debug:
direction: BOTH
dummy_receiver: True
after:
delimiter: [0X55, 0XCC]
sequence:
- lambda: |-
if ((millis() - id(last_update_ld2450)) <= 500) {
return;
id(last_update_ld2450) = millis();
// p1
int16_t p1_x = (uint16_t((bytes[5] << 8) | bytes[4] ));
if ((bytes[5] & 0x80) >> 7){
p1_x -= pow(2, 15);
}else{
p1_x = 0 - p1_x;
int16_t p1_y = (uint16_t((bytes[7] << 8) | bytes[6] ));
if ((bytes[7] & 0x80) >> 7){
p1_y -= pow(2, 15);
}else{
p1_y = 0 - p1_y;
int p1_speed = (bytes[9] << 8 | bytes[8] );
if ((bytes[9] & 0x80) >> 7){
p1_speed -= pow(2, 15);
}else{
p1_speed = 0 - p1_speed;
int16_t p1_distance_resolution = (uint16_t((bytes[11] << 8) | bytes[10] ));
// p2
int16_t p2_x = (uint16_t((bytes[13] << 8) | bytes[12] ));
if ((bytes[13] & 0x80) >> 7){
p2_x -= pow(2, 15);
}else{
p2_x = 0 - p2_x;
int16_t p2_y = (uint16_t((bytes[15] << 8) | bytes[14] ));
if ((bytes[15] & 0x80) >> 7){
p2_y -= pow(2, 15);
}else{
p2_y = 0 - p2_y;
int p2_speed = (bytes[17] << 8 | bytes[16] );
if ((bytes[17] & 0x80) >> 7){
p2_speed -= pow(2, 15);
}else{
p2_speed = 0 - p2_speed;
int16_t p2_distance_resolution = (uint16_t((bytes[19] << 8) | bytes[18] ));
// p3
int16_t p3_x = (uint16_t((bytes[21] << 8) | bytes[20] ));
if ((bytes[21] & 0x80) >> 7){
p3_x -= pow(2, 15);
}else{
p3_x = 0 - p3_x;
int16_t p3_y = (uint16_t((bytes[23] << 8) | bytes[22] ));
if ((bytes[23] & 0x80) >> 7){
p3_y -= pow(2, 15);
}else{
p3_y = 0 - p3_y;
int p3_speed = (bytes[25] << 8 | bytes[24] );
if ((bytes[25] & 0x80) >> 7){
p3_speed -= pow(2, 15);
}else{
p3_speed = 0 - p3_speed;
int16_t p3_distance_resolution = (uint16_t((bytes[27] << 8) | bytes[26] ));
bool p1_vaild = (p1_x != 0 || p1_y > 0);
bool p2_vaild = (p2_x != 0 || p2_y > 0);
bool p3_vaild = (p3_x != 0 || p3_y > 0);
// zone exlude 1
int16_t target_count_in_zone_ex1 = 0;
int16_t zone_ex1_x_min = id(zone_ex1_x_begin).state;
int16_t zone_ex1_x_max = id(zone_ex1_x_end).state;
int16_t zone_ex1_y_min = id(zone_ex1_y_begin).state;
int16_t zone_ex1_y_max = id(zone_ex1_y_end).state;
bool p1_zone_ex_enter = false;
bool p2_zone_ex_enter = false;
bool p3_zone_ex_enter = false;
if (id(zone_ex1_enable).state){
if (p1_vaild){
if (p1_x >= zone_ex1_x_min && p1_x <= zone_ex1_x_max && p1_y >= zone_ex1_y_min && p1_y <= zone_ex1_y_max){
p1_zone_ex_enter = true;
target_count_in_zone_ex1 ++;
if (p2_vaild){
if (p2_x >= zone_ex1_x_min && p2_x <= zone_ex1_x_max && p2_y >= zone_ex1_y_min && p2_y <= zone_ex1_y_max){
p2_zone_ex_enter = true;
if (p3_vaild){
if (p3_x >= zone_ex1_x_min && p3_x <= zone_ex1_x_max && p3_y >= zone_ex1_y_min && p3_y <= zone_ex1_y_max){
p3_zone_ex_enter = true;
bool has_target_in_zone_ex1 = (target_count_in_zone_ex1 > 0);
int16_t all_target_counts = 0;
if (p1_vaild && !p1_zone_ex_enter){
all_target_counts ++;
if (p2_vaild && !p2_zone_ex_enter){
if (p3_vaild && !p3_zone_ex_enter){
bool has_target_in_zone_all = (all_target_counts > 0);
// zone 1 check
int16_t target_count_in_zone1 = 0;
int16_t zone1_x_min = id(zone1_x_begin).state;
int16_t zone1_x_max = id(zone1_x_end).state;
int16_t zone1_y_min = id(zone1_y_begin).state;
int16_t zone1_y_max = id(zone1_y_end).state;
if (p1_x >= zone1_x_min && p1_x <= zone1_x_max && p1_y >= zone1_y_min && p1_y <= zone1_y_max){
target_count_in_zone1 ++;
if (p2_x >= zone1_x_min && p2_x <= zone1_x_max && p2_y >= zone1_y_min && p2_y <= zone1_y_max){
if (p3_x >= zone1_x_min && p3_x <= zone1_x_max && p3_y >= zone1_y_min && p3_y <= zone1_y_max){
bool has_target_in_zone1 = (target_count_in_zone1 > 0);
// zone 2 check
int16_t target_count_in_zone2 = 0;
int16_t zone2_x_min = id(zone2_x_begin).state;
int16_t zone2_x_max = id(zone2_x_end).state;
int16_t zone2_y_min = id(zone2_y_begin).state;
int16_t zone2_y_max = id(zone2_y_end).state;
if (p1_x >= zone2_x_min && p1_x <= zone2_x_max && p1_y >= zone2_y_min && p1_y <= zone2_y_max){
target_count_in_zone2 ++;
if (p2_x >= zone2_x_min && p2_x <= zone2_x_max && p2_y >= zone2_y_min && p2_y <= zone2_y_max){
if (p3_x >= zone2_x_min && p3_x <= zone2_x_max && p3_y >= zone2_y_min && p3_y <= zone2_y_max){
bool has_target_in_zone2 = (target_count_in_zone2 > 0);
// zone 3 check
int16_t target_count_in_zone3 = 0;
int16_t zone3_x_min = id(zone3_x_begin).state;
int16_t zone3_x_max = id(zone3_x_end).state;
int16_t zone3_y_min = id(zone3_y_begin).state;
int16_t zone3_y_max = id(zone3_y_end).state;
if (p1_x >= zone3_x_min && p1_x <= zone3_x_max && p1_y >= zone3_y_min && p1_y <= zone3_y_max){
target_count_in_zone3 ++;
if (p2_x >= zone3_x_min && p2_x <= zone3_x_max && p2_y >= zone3_y_min && p2_y <= zone3_y_max){
if (p3_x >= zone3_x_min && p3_x <= zone3_x_max && p3_y >= zone3_y_min && p3_y <= zone3_y_max){
bool has_target_in_zone3 = (target_count_in_zone3 > 0);
// public all info
if (id(target1_x).state != p1_x){
id(target1_x).publish_state(p1_x);
if (id(target1_y).state != p1_y){
id(target1_y).publish_state(p1_y);
float p1_m_speed = float(p1_speed) / 100.0;
if (id(target1_speed).state != p1_m_speed){
id(target1_speed).publish_state(p1_m_speed);
if (id(target1_resolution).state != p1_distance_resolution){
id(target1_resolution).publish_state(p1_distance_resolution);
if (id(target2_x).state != p2_x){
id(target2_x).publish_state(p2_x);
if (id(target2_y).state != p2_y){
id(target2_y).publish_state(p2_y);
if (id(target2_speed).state != p2_speed){
id(target2_speed).publish_state(p2_speed);
if (id(target2_resolution).state != p2_distance_resolution){
id(target2_resolution).publish_state(p2_distance_resolution);
if (id(target3_x).state != p3_x){
id(target3_x).publish_state(p3_x);
if (id(target3_y).state != p3_y){
id(target3_y).publish_state(p3_y);
if (id(target3_speed).state != p3_speed){
id(target3_speed).publish_state(p3_speed);
if (id(target3_resolution).state != p3_distance_resolution){
id(target3_resolution).publish_state(p3_distance_resolution);
// publish target info
if (id(all_target_count).state != all_target_counts){
id(all_target_count).publish_state(all_target_counts);
id(any_target_exsits).publish_state(has_target_in_zone_all);
if (id(zone1_target_count).state != target_count_in_zone1){
id(zone1_target_count).publish_state(target_count_in_zone1);
id(zone1_target_exsits).publish_state(has_target_in_zone1);
if (id(zone2_target_count).state != target_count_in_zone2){
id(zone2_target_count).publish_state(target_count_in_zone2);
id(zone2_target_exsits).publish_state(has_target_in_zone2);
if (id(zone3_target_count).state != target_count_in_zone3){
id(zone3_target_count).publish_state(target_count_in_zone3);
id(zone3_target_exsits).publish_state(has_target_in_zone3);
// zout
if (id(zone_ex1_target_count).state != target_count_in_zone_ex1){
id(zone_ex1_target_count).publish_state(target_count_in_zone_ex1);
id(zone_ex1_target_exsits).publish_state(has_target_in_zone_ex1);
if (!id(init_zone_publish)){
id(init_zone_publish) = true;
Yes, the current hlkradartool app provides its own set of zone mechanisms, but this one has this behavior:
- Its include and exclude zones are independent, you canāt have both at the same time.
- Its zones affect the final coordinate output, which means that if include zones are turned on, then only the x and y coordinates will be output for include zones.Whereas for excluded zones, then the targets in the excluded zones act like black holes, resulting in no output for x and y.
Since there is no raw coordinate output, the zone mechanism in ha is independent (for screekās code), which has the advantage that wo m always have access to xy coordinates.This is pretty cool when paired with a map, at the cost, of course, of typing in those numbers is kind of a pain in the ass.
Maybe in the future some improvements could be made that could also show what happens to the regions in the app, I think it might be a good idea.
Currently uncly-yuruās library uses a different idea, exposing the appās settings and the region of judgment, if we understand it correctly.It may then lead to that black hole problem, where the target is only output when it is in the zone.
Weāll continue to feed back to hlk to always have raw coordinate output in the future.And the ability to include both regions + exclude regions everything combination available in the app.
Just wanted to say thanks, new to HA and people mentioning screek helped point me to many useful reading material.
Back to the issue I have, noted on what you shared. However as mentioned I face the issue of the zones in HA reporting clear despite being in the zone. Pictures for your reference.
I think itās most likely a negative number problem, if everything looks fine but then it doesnāt go into the region, thereās a chance that someone got it wrong in a system where the x-coordinate contains a negative number, in fact -10 is less than -2, and one should write -2 in x-begin and -10 in x-end.
We hope that the next step will be to improve the firmware to automatically handle this kind of easily confused numerical errors, and reduce the numerical stress for everyone.
Yup that someone is me, thanks all fixed!
Still testing this in my current apartment before my new place is ready, intend to add a BH1750 to this. Hopefully not too difficult
The esphome is powerful and probably easier than you think, good luck.
Someone know where find a case for LD2450 stl to print ?
I have a case which is with custom ESP board, I think it is not suitable for you, If you tell me what ESP board youāre using, maybe I can make one for you, of course, it is free!
i have a esp32-c3 super miniā¦
removed for off topic, this is ESPHome section
just opened a net topic instead
how can you check if the sensor is working in single-target or multi-target mode?
i mean, in the datasheet there is a serial command to set target mode, but no config data seems to be provided on serial (if not as ack on serial command), but when you open the app it is able to understand if the sensor is single or multi target.
What data is it using?
