Home Assistant Add-on: Caddy 2
So my reverse proxy stopped working and I cant figure out what is going on. I was fixing a light switch and my wife accidentally turned off a breaker which seems to have broken my fragile networking situation.
Everything has been restarted in the network and although there was some warnings about improper shutdowns everything seems to be back online.
I have checked that that the devices have all taken up the proper local ips which were reserved anyway. The duckdns service is working and it appears that my modem never lost the same IP.
I have checked the log which showed no error just a warning about not using caddy_fmt to fix up my caddy file. I cannot remember if the log should say it successfully retrieved certificates explicitly which I dont see.
I have reverted back to a known working configuration of caddy 1 without success! I have been at it for over and hour.
I guess I am wondering if the service that provides the certificates is still working at this point. I am not sure how to proceed?
Addendum: I went back to my duckdns account and o’boy they changed there login options and I had to recreate an account but was able to get back my domain. I changed to the new token generated and added to the duckdns addon and changed it in the caddyfile. I noticed my email that was required to retrieve letsencrypt was also there. Does that even need to be there? I am not getting too far on this :expressionless:
it uses the email if for instance your cert hasn’t renewed and is expiring, Check the IP address is correct for the domain and your router didn’t just decide to use a different one. Also check in Home Assistant Supervisor>System>host that the ip address is correct.
Thanks for the response. So as I pulled out my hair at my residence trying to figure out the problem my wife came home and mentioned she had access without issue. I immediately disabled wifi on my phone switching to mobile data and could get access to my domain. That was alot of wasted time on my part but such is life. I still cannot access my domain from my local network but I can get local address access via the local IP addresses. I haven’t looked into it but have a vague memory of this happening before.
I can ping my domain from local though. Ah the mysteries of networking.
your router must support nat loopback for the domain to work internally
Thank you for that information .I’ll look through the settings but the hardware that was in place hasn’t changed and was only restarted. Could it be related to trusted proxies in my config file for HA. Caddy in HA reverse proxies for all docker containers including containers on a separate physical installation.
Edit: I’ll conclude my discussion since it seems this is not Caddy related. Feel free to chime in if I’m wrong anybody. Thanks Dave I’ll check into loopback on my router
Just found it finally, not caddy, my Suricata IPS was blocking the delete request.
Hello all
Wondering if any of you media enthusiasts might be able to help me with my stack. Remote access to Plex seems a little flaky. Can I optimize my caddy file to make it more reliable? The plex web interface shows plex as intermittently not remotely accessible.
In plex under remote connections I have this:
Private_internal_plexserver_ip:32400 <-- Public_external_ip:443 <-- Internet
In Caddy 1 adding ā€œtransparentā€ to the caddy file for plex sorted this but I think this is the default for caddy 2.
Any feedback would be appreciated
Ok crickets around here. Any body have experience reverse proxying a unify controller(not the home assistant add-on) on the same machine
Just an FYI caddy has its own forum here. For specific caddy configuration and how to questions I’d recommend looking and asking there. Since that’s dedicated to caddy and where the caddy experts hang out
I was aware of the forum as it came up in my searches however any excerpts from that forum in my Caddyfile have not resulted in success. The configuration might have been encountered by other users here so I had hoped to hear from someone.
Thanks for the feedback. I will keep trying
I have recently started getting deceptive site warnings from chrome and when loading pages through my domain name they appear incomplete. I am using duckdns for my domain. I have also noted that my google assistant integration that I have had for a number of years has been not available with the statement "yourappname"testing is not available intermittently(as in works this time but not next time) I dont believe I made any changes to my setup.
Im definitely not up on my networking but it seems domain related maybe, do I thought I would try a new domain. What changes do I have to make to my Caddy file to use my new domain as I can see some duckdns entry near the top of that file?
I got crowdsec homeassistant addon to integrate with this addon. Posted a community guide, if it helps:
@berichta I have and issue and I am not sure if its home assistant or this addon. The addon appears to be working but it shows as not started in home assistant. The logs dont show anything as far as I can tell. Hitting the start button doesn’t really do anything and doesn’t seem to evoke an error in the log. Any help with what’s going on?
edit: I do see some errors now not sure if its pertitnent
{"level":"error","ts":16686.370,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"http2: stream closed"} {"level":"error","ts":16686.472,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"http2: stream closed"}
Hi @dasbooter,
From what you describe I take that the UI isn’t matching the state of the add-on.
This can happen, or at least happened to me in a similar fashion. In such cases, I usually reloaded the webpage with cleard cache. For me (on Mac) it would be cmd + shift + r.
For the listed errors I have no clue yet. :slightly_frowning_face:
Thanks for replying. The behavior also made me think it was just a cache issue but I have cleared the cache and even tried a different browser but it still shows as not started with the red dot in the upper right corner
How would I completely scrub all parts of the addon so I can start from scratch with it. Would all the folders in the base ssl directory be purged also? I have tried reverting to previous configuration but that didnt fix the problem and I didnt realize that a back and forth with backups can be a little problematic with other things
this is the error showing now {"level":"error","ts":1668770179.934891,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","error":"http2: stream closed"}
I have tried to use services to stop start restart the addon but they all give a failed to start service undefined error
final edit: Deleted anything I thought was caddy related including all folders in SSL(backed up but still probably shouldn’t have done that). Removed the addon restarted HA then also restarted the actual Virtual Machine. Reinstalled the addon and put back my Caddyfile. Now finally HA recognizes the addon as started. Problem with the shotgun approach is I dont know what the problem was.
Can somebody help me with simple mark down I cant get it right and I would like to incorporate the security back into my simple caddy file. Ive had to temporarily move away from duckdns for home assistant specifically as I am having problems with google assistant integration. I am still using duckdns as you can see for somethings. I cant seem to get the security part back into my caddy file without causing an error.
This part defined as common:
(common) {
	tls {
		dns duckdns redacted
		on_demand
	header {
		Strict-Transport-Security "max-age=31536000; includeSubdomains; preload"
		X-XSS-Protection "1; mode=block"
		X-Content-Type-Options "nosniff"
		Referrer-Policy "same-origin"
		Content-Security-Policy "frame-ancestors redacted.duckdns.org *.redacted.duckdns.org"
		-Server
		Permissions-Policy "geolocation=(self), microphone=()"
redacted.twilightparadox.com {
	reverse_proxy redacted:8123
ombi.redacted.duckdns.org {
	reverse_proxy redacted:3579
tautalli.redacted.duckdns.org {
	reverse_proxy redacted:8181
portainer.redacted.duckdns.org {
	reverse_proxy redacted:9000
plex.redacted.duckdns.org {
	reverse_proxy redacted:32400
redacted.redacted.duckdns.org {
	reverse_proxy redacted:redacted
	reverse_proxy redacted:redacted {
		transport http {
			tls
			tls_insecure_skip_verify
prowlarr.redacted.duckdns.org {
	reverse_proxy redacted:9696
sonarr.redacted.duckdns.org {
	reverse_proxy redacted:8989
radarr.redacted.duckdns.org {
	reverse_proxy redacted:7878
organizr.redacted.duckdns.org {
	reverse_proxy redacted:8006
OK? I tried to go back to my old caddy file which uses on duckdns with dns challenge and I am getting ā€œError during parsing: getting module named ā€˜dns.providers.duckdns’: module not registered: dns.providers.duckdns.ā€ I thought this addon was compiled with the duckdns dns module? Nevermind it was not I had to download one from the caddywebisite with the addon (linux amd64 and name it caddy not Caddy in /share/caddy/
Curious if anyone is getting a deceptive site warning using caddy2 in home assistant? mine started yesterday and all of my sites behind my router are showing deceptive, not just home assistant.
caddyfile
# Synology
https://liquidxpe.somename.com {
        reverse_proxy https://XX.XX.XX.48:5001 {
                transport http {
# Unifi
https://liquiduni.somename.com {
        reverse_proxy https://XX.XX.XX.240:8443 {
                transport http {
# Edgerouter
https://liquidrt.somename.com {
        reverse_proxy https://XX.XX.XX.1:8440 {
                transport http {
# DSM Portainer
https://dsmportainer.somename.com {
        reverse_proxy https://XX.XX.XX.48:9443 {
                transport http {
# HA Portainer
https://haportainer.somename.com {
        reverse_proxy http://XX.XX.XX.240:9000 {
                transport http
# Radarr
https://radarr.somename.com {
        reverse_proxy http://XX.XX.XX.48:7878 {
                transport http
# Sonarr
https://sonarr.somename.com {
        reverse_proxy http://XX.XX.XX.48:8989 {
                transport http
# Readarr
https://read.somename.com {
        reverse_proxy http://XX.XX.XX.48:8787 {
                transport http
# Lidarr
https://music.somename.com {
        reverse_proxy http://XX.XX.XX.48:8686 {
                transport http
# SabNZBD
https://sab.somename.com {
        reverse_proxy http://XX.XX.XX.48:8080 {
                transport http
# automate-myhome
https://automate-myhome.com {
        reverse_proxy http://XX.XX.XX.240:49153 {
                transport http
# HomeAssist
https://homeaccess.somename.com {
        reverse_proxy https://XX.XX.XX.220:8123 {
                transport http {
#Frigate
https://frigate.somename.com {
        reverse_proxy http://XX.XX.XX.75:5000 {
                transport http
#Search
https://search.somename.com {
        reverse_proxy http://XX.XX.XX.48:5055 {
                transport http
#Transcode
https://transcode.somename.com {
        reverse_proxy http://XX.XX.XX.75:8265 {
                transport http
#Plex
https://watch.somename.com {
        reverse_proxy http://XX.XX.XX.75:32400 {
                transport http
link dead now?
strange i cant even add your repository
nevermind. seems it works on Edge browser only…
can someone please show me their config for very basic https access to my HA machine?
what to put in here?
i only need local https://192.168.1.229:8123
as of now, i access my HA OS’s GUI via http://192.168.1.229:8123
i wont need to access the gui remotely or anything fancy like that
i did try but this does not work when i try to open tung.ha (tung.ha is not a real site)
When using the Home Assistant add-on, how do I use cloudflare for the DNS challenge? I’m getting the following error, which I assume means it isn’t included in the add-on.
Error during parsing: getting module named ā€˜dns.providers.cloudflare’: module not registered: dns.providers.cloudflare
