Sorry, i missed to set this thread to watching and missed all of your replies.
It is solved since version 4.5.2-r0-ls250, login with whitelist is possible again. Thank you Alex!
EDIT: Just updated to the 4.5.2-r0-ls250-2 and i found the reason for the message. Normally i just update an addon and it restarts itself and works (so i thought). But with this addon, i have to manually restart the addon, without it i get the unauthorized error (as posted above), after a restart all is fine.
Typically PEBKAC
after last update i see that qbittorent set download path to /config/addons_config/Downloads, no matter what in SavePath. If i try to set download directory in qb UI, it will be reset after restart. Is it known issue?
[migrations] started
[migrations] no migrations found
cont-init: info: running /etc/cont-init.d/00-banner.sh
Add-on: Qbittorrent
qBittorrent is a bittorrent client
βββββββββββββββββββββββββββββββββββββββ
βββ βββββββββββ βββββββ
βββ ββββββββββββββββββββ
βββ ββββββββββββββ βββ
βββββββββββββββββββ βββββββ
Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User UID: 0
User GID: 0
Add-on version: 4.5.2-r0-ls250-5
You are running the latest version of this add-on.
System: Home Assistant OS 9.5 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.3.5
Home Assistant Supervisor: 2023.03.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums
https://github.com/alexbelgium/hassio-addons
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/00-folders.sh
cont-init: info: /etc/cont-init.d/00-folders.sh exited 0
cont-init: info: running /etc/cont-init.d/01-custom_script.sh
[01:00:45] INFO: Execute /config/addons_autoscripts/qbittorrent.sh if existing
[01:00:45] INFO: ... no script found
cont-init: info: /etc/cont-init.d/01-custom_script.sh exited 0
cont-init: info: running /etc/cont-init.d/30-nginx.sh
cont-init: info: /etc/cont-init.d/30-nginx.sh exited 0
cont-init: info: running /etc/cont-init.d/90-dns_set.sh
[01:00:47] INFO: DNS SERVERS set to 1.1.1.1 8.8.8.8
cont-init: info: /etc/cont-init.d/90-dns_set.sh exited 0
cont-init: info: running /etc/cont-init.d/91-qbittorrent_configuration.sh
[01:00:47] INFO: Downloads can be found in /mnt/downloads
[01:00:48] INFO: Whitelisted subsets will not require a password : localhost,127.0.0.1,172.30.0.0/16,192.168.0.0/16
[01:00:48] INFO: WEBUI username set to admin
[01:00:48] INFO: Alternate UI enabled : vuetorrent. If webui don't work, disable this option
[01:00:51] INFO: Default username/password : admin/adminadmin
[01:00:51] INFO: Configuration can be found in /config/addons_config/qBittorrent
cont-init: info: /etc/cont-init.d/91-qbittorrent_configuration.sh exited 0
cont-init: info: running /etc/cont-init.d/92-local_mounts.sh
cont-init: info: /etc/cont-init.d/92-local_mounts.sh exited 0
cont-init: info: running /etc/cont-init.d/92-smb_mounts.sh
Mounting smb share(s)...
Using domain WORKGROUP
Using PUID 0 and PGID 0
[01:00:56] INFO: ... //192.168.88.2/downloads successfully mounted to /mnt/downloads with options ,vers=1.0,noserverino
cont-init: info: /etc/cont-init.d/92-smb_mounts.sh exited 0
cont-init: info: running /etc/cont-init.d/93-openvpn.sh
[01:00:56] INFO: Direct connection without VPN enabled
cont-init: info: /etc/cont-init.d/93-openvpn.sh exited 0
[custom-init] No custom files found, skipping...
WebUI will be started shortly after internal preparations. Please wait...
services-up: info: copying legacy longrun nginx (no readiness notification)
[ls.io-init] done.
[01:00:59] INFO: Starting NGinx...
The 4.5.3 update causes my Rpi4 HA setup to reboot, afterwards it becomes irresponsive, looks like supervisor canβt start properly. Some pages work, but no add-on is available nor any restore option. I canβt check system logs for details on the issue. Moreover, my local network becomes so overloaded, various system begin to report network outage. The only way to remedy is completely re-install NA and restore it from the previous backup.
My qBittorrent setup uses VPM and Samba drives, hereβs the configuration:
I might try but it has to wait till weekend as I will have to reinstall everything again. There are several logs, one in qBittorrent directory isnβt the same as shown in the add-on log tab, Iβll try to collect whatever I find. If you could suggest locations for logs it would be awesome.
Thank you for offering to look into the issue
This is really surprising (in addition to inconvenient) to need to reinstall everythingβ¦ Isnβt it a matter of free space remaining? As normally when you reboot the system, the add-on should be stopped so the only way it can affect the system would be through potential leftover files.
Or could it be an issue with SD card?
The main log is transient and only shown in the add-on log⦠Which could be not accessible if the system hangs when the add-on runs
Iβve narrowed the problem down a bit. Iβve updated HA to the latest version, tried the latest qBittorrent patch, same result, HA reboots, network flooded, etc. Then Iβve removed QBT completely and installed the update with vanilla configuration. This worked, albeit QTB UI was giving me a big red warning about using old configuration options (even for vanilla install, and there was no data which options are now βoldβ). Then Iβve added OpenVPN config, QBT restarted ok. Lastly, I added βnetworkdisksβ/βcifβ parameters - and ka-boom. I have Synology NAS with shared folders, works perfectly fine with QBT 4.5.2 but apparently not with 4.5.3
Iβve also found this thread - Updated, entire network crashing - this is exactly what happens with my system, however in my case the culprit is the lasted QBT and my router is ASUS. It looks like HA is prone to this βnetwork floodβ issue, not necessarily related to the latest HA version.
Indeedβ¦ If the issue is a network flood linked to the addon however it shouldnβt affect your HA when starting (if the addon is started) or if internet is disconnected, right ?
Are you on HAos, or a virtual machine ? As from the thread you were refering it seems that ajusting network parameters could help
From what I can tell, it seems like smbv1/CIFS is deprecated entirely and causes the system to crash when trying to mount.
If have add-ons using SMBv1/cifs, if you can plug directly into the host and use the cli even if itβs only for 20-30seconds before the system crashes and reboots. Try to disable the add ons utilizing CiFS, and the system should boot or not crash long enough to bring up the main HA container, and the webui, at which point you can disable those add-ons on boot.
Need to submit a bug in alexbelgium repo to update the smb/cifs method used in the containers
My add-ons actually try all smb versions starting from 3 and only using smbv1 if the user himself is using it. For example some routers such as fritzbox only use smbv1. Si it seems more on the user side.,. On my own system I use the cifs method and never had issues. I use the samba nas add-on that publishes all disks on smb
However, something did change between 4.5.2 and 4.5.3 qBittorrent versions, the latter skips smb3 and smb2, despite NAS support. Assuming itβs the real culprit, itβs definitely QBTβs regression
Iβve just tried disabling smb1 support on my Synology NAS (enabled by default) and an update to QBT 4.5.3 went without an issue. So smb1 is without a doubt the root cause. While we may argue that itβs a βclient side faultβ, the real problem is with QBT 4.5.3 skipping smb3 or smb2 protocol versions on NAS and only connecting at smb1 level. It wasnβt happening in 4.5.2, and if I may suggest should be fixed as many network servers support smb1 out of the box, or at very least documenting the smb version requirement
