I’ve been having problems recently. But have reinstalled the addon since then and added my PIA ovpn file and credentials to the configuration. However, the addon is not working and I’m not making any progress reading the logs… I’ve added my log below.
I guess the most important errors are
s6-rc: fatal: unable to take locks: Resource busy
if: fatal: unable to spawn s6-test: No such file or directory
nginx: [emerg] bind() to 172.30.33.5:8099 failed (98: Address in use)
Is this a problem with the OpenVPN configuration?
Setting permissions for the config.yaml directory
Load environment variables from /config/config.yaml if existing
If accessing the file with filebrowser it should be mapped to /addon_configs/db21ed7f-qbittorrent/config.yaml
Wiki here on how to use : github.com/alexbelgium/hassio-addons/wiki/Add‐ons-feature-:-add-env-variables
... no env variables found, exiting
/etc/cont-init.d/01-custom_script.sh: executing
Execute /config/*-qbittorrent/qbittorrent.sh if existing
Wiki here : github.com/alexbelgium/hassio-addons/wiki/Add-ons-feature-:-customisation
/etc/cont-init.d/30-nginx.sh: executing
/etc/cont-init.d/90-dns_set.sh: executing
[15:15:34] INFO: DNS SERVERS set to 1.1.1.1 8.8.8.8
/etc/cont-init.d/91-qbittorrent_configuration.sh: executing
[15:15:34] INFO: Downloads can be found in /share/qBittorrent
[15:15:34] INFO: Whitelisted subsets will not require a password : localhost, 127.0.0.1, 172.30.0.0/16, 192.168.0.0/16
[15:15:34] INFO: WEBUI username set to admin
[15:15:34] INFO: Alternate UI enabled : vuetorrent. If webui don't work, disable this option
[15:15:35] INFO: Default username/password : admin/homeassistant
[15:15:35] INFO: Configuration can be found in /config/qBittorrent
/etc/cont-init.d/92-qbit_manage.sh: executing
/etc/cont-init.d/93-openvpn.sh: executing
[15:15:35] INFO: ----------------------------
[15:15:35] INFO: Openvpn enabled, configuring
... configured ovpn file : using /addon_configs/db21ed7f-qbittorrent/openvpn/config.ovpn
... openvpn correctly set, qbittorrent will run tunnelled through openvpn
Using container binding
... deleting previous interface settings
Starting the upstream container
[migrations] started
[migrations] no migrations found
Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User UID: 0
User GID: 0
[custom-init] No custom files found, skipping...
crond: crond (busybox 1.36.1) started, log level 8
2024-01-10 15:15:36 DEPRECATED OPTION: --cipher set to 'aes-128-cbc' but missing in --data-ciphers (AES-256-GCM:AES-128-GCM:CHACHA20-POLY1305). OpenVPN ignores --cipher for cipher negotiations.
2024-01-10 15:15:36 OpenVPN 2.6.8 x86_64-alpine-linux-musl [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
2024-01-10 15:15:36 library versions: OpenSSL 3.1.4 24 Oct 2023, LZO 2.10
2024-01-10 15:15:36 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2024-01-10 15:15:36 CRL: loaded 1 CRLs from file -----BEGIN X509 CRL-----
MIICWDCCAUAwDQYJKoZIhvcNAQENBQAwgegxCzAJBgNVBAYTAlVTMQswCQYDVQQI
EwJDQTETMBEGA1UEBxMKTG9zQW5nZWxlczEgMB4GA1UEChMXUHJpdmF0ZSBJbnRl
cm5ldCBBY2Nlc3MxIDAeBgNVBAsTF1ByaXZhdGUgSW50ZXJuZXQgQWNjZXNzMSAw
HgYDVQQDExdQcml2YXRlIEludGVybmV0IEFjY2VzczEgMB4GA1UEKRMXUHJpdmF0
ZSBJbnRlcm5ldCBBY2Nlc3MxLzAtBgkqhkiG9w0BCQEWIHNlY3VyZUBwcml2YXRl
aW50ZXJuZXRhY2Nlc3MuY29tFw0xNjA3MDgxOTAwNDZaFw0zNjA3MDMxOTAwNDZa
MCYwEQIBARcMMTYwNzA4MTkwMDQ2MBECAQYXDDE2MDcwODE5MDA0NjANBgkqhkiG
9w0BAQ0FAAOCAQEAQZo9X97ci8EcPYu/uK2HB152OZbeZCINmYyluLDOdcSvg6B5
jI+ffKN3laDvczsG6CxmY3jNyc79XVpEYUnq4rT3FfveW1+Ralf+Vf38HdpwB8EW
B4hZlQ205+21CALLvZvR8HcPxC9KEnev1mU46wkTiov0EKc+EdRxkj5yMgv0V2Re
ze7AP+NQ9ykvDScH4eYCsmufNpIjBLhpLE2cuZZXBLcPhuRzVoU3l7A9lvzG9mjA
5YijHJGHNjlWFqyrn1CfYS6koa4TGEPngBoAziWRbDGdhEgJABHrpoaFYaL61zqy
MR6jC0K2ps9qyZAN74LEBedEfK7tBOzWMwr58A==
-----END X509 CRL-----
2024-01-10 15:15:36 TCP/UDP: Preserving recently used remote address: [AF_INET]89.149.24.207:1198
2024-01-10 15:15:36 UDPv4 link local: (not bound)
2024-01-10 15:15:36 UDPv4 link remote: [AF_INET]89.149.24.207:1198
2024-01-10 15:15:36 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
2024-01-10 15:15:36 [amsterdam434] Peer Connection Initiated with [AF_INET]89.149.24.207:1198
2024-01-10 15:15:36 TUN/TAP device tun0 opened
2024-01-10 15:15:36 /sbin/ip link set dev tun0 up mtu 1500
2024-01-10 15:15:36 /sbin/ip addr add dev tun0 10.79.112.145/24
2024-01-10 15:15:36 /etc/openvpn/up.sh tun0 1500 0 10.79.112.145 255.255.255.0 init
2024-01-10 15:15:36 Initialization Sequence Completed
WebUI will be started shortly after internal preparations. Please wait...
******** Information ********
To control qBittorrent, access the WebUI at: http://localhost:8080
Connection to localhost (127.0.0.1) 8080 port [tcp/http-alt] succeeded!
[15:15:37] INFO: Starting NGinx...
[ls.io-init] done.
[ls.io-init] done.
[15:15:51] INFO: Starting NGinx...
2024/01/10 15:15:51 [emerg] 976#976: bind() to 172.30.33.5:8099 failed (98: Address in use)
2024/01/10 15:15:51 [emerg] 976#976: still could not bind()
nginx: [emerg] still could not bind()
[15:16:03] INFO: Starting NGinx...
2024/01/10 15:16:03 [emerg] 1014#1014: bind() to 172.30.33.5:8099 failed (98: Address in use)
2024/01/10 15:16:03 [emerg] 1014#1014: still could not bind()
