Good morning, I’m trying all kinds of ways to make the system work, but I’m not capable.
I followed all the steps, but without. success.
I’m working with raspbian and has no docker
any help would be great
homeassistant@Jarvis : ~/.homeassistant/paradox/ParadoxIP150v2-master $ python IP150-MQTTv2.py
logging to file /var/log/paradoxip.log
reading config
INFO:root:logging complete
2018-10-26 15:06:33,603 INFO logging complete
ERROR:root:test
2018-10-26 15:06:33,604 ERROR test
INFO:root:config.ini file read successfully: 0
2018-10-26 15:06:33,606 INFO config.ini file read successfully: 0
config read
INFO:root:State01:Attempting connection to MQTT Broker: 127.0.0.1:1883
2018-10-26 15:06:33,606 INFO State01:Attempting connection to MQTT Broker: 127.0.0.1:1883
INFO:root:Connected to MQTT broker with result code 5
2018-10-26 15:06:33,611 INFO Connected to MQTT broker with result code 5
INFO:root:State01:MQTT client subscribed to control messages on topic: Paradox/C/#
2018-10-26 15:06:33,612 INFO State01:MQTT client subscribed to control messages on topic: Paradox/C/#
INFO:root:State02:Connecting to IP Module
2018-10-26 15:06:33,613 INFO State02:Connecting to IP Module
trying to connect 192.168.1.74
INFO:root:Connecting to 192.168.1.74
2018-10-26 15:06:33,614 INFO Connecting to 192.168.1.74
connected
INFO:root:Logging into alarm system…
2018-10-26 15:06:33,617 INFO Logging into alarm system…
INFO:root:Login to alarm panel successful
2018-10-26 15:06:33,868 INFO Login to alarm panel successful
2018-10-26 15:06:34,617 INFO Connected to MQTT broker with result code 5
2018-10-26 15:06:35,622 INFO Connected to MQTT broker with result code 5
INFO:root:State02: Logged into IP modeule successfully
2018-10-26 15:06:35,875 INFO State02: Logged into IP modeule successfully
INFO:root:State03:Listening for events…
2018-10-26 15:06:35,876 INFO State03:Listening for events…
2018-10-26 15:06:36,626 INFO Connected to MQTT broker with result code 5
2018-10-26 15:06:37,631 INFO Connected to MQTT broker with result code 5
