Hi Matthew. Did you have some time to have a look? I have tried myself without luck…
Hi, regarding HACS, I’ve been waiting for quite a while, and it seems like I might have been forgotten. The HACS requirements should be met, but I haven’t received a reviews yet. I’ll try to escalate this and refresh the process.
As for issue #6, I would need the specific device in hand to properly test it. This seems to also be related to an issue reported by @plhc but I’m not sure. Honestly, I’m not sure what exactly I should change there. The only thing I could do is probably remove the NetAtmo control (it was part of a school project, so I might as well get rid of it) to make everything work correctly.
That said, I still have a lot of schoolwork to deal with. Also, I no longer have the Sonoff device (I moved), but if I order a new one, I’ll try to fix the issue and simplify the integration a bit.
This would be amazing if you could map a “Stop Cover” action or something, so blinds could be paused, mine has an Up, Down and Pause button
