Yes. I am connected to the mesh on my iMac, and my phone. The Blue is physically patched into the mesh node. When I try to ping Blue from the iMac, it says ping: sendto: Host is down
When I try to connect to Blue from Safari on the phone the browser doesn’t connect.
When I try the HA app, it says ‘Uh oh’ and Unknown errorL URLSessionTask failed with error: The request timed out
Finally when I ping 8.8.8.8 from HA command line, or any other IP that I can see on the network using the phone or the router, it fails. Oddly pinging its own address from the command line tells me its alive.
I feel your pain although it will not help to say I have just done the same (bought a Blue) and it just worked! Transferred from my Pi no bother. The only additional task I had to do was go into the Supervisor settings and set the Static IP address to what I used before.
That’s a good thought. I mean, no, I don’t think I do, but it may be easier to scrobble one of those and configure things through the UI than battle this ethernet connection whilst blocking the kids’ tv
Sorry, I probably didn’t explain that well. When I used nmcli to set ipv4.address, I forgot it adds /32 if you don’t specify a subnet mask. That’s why I removed that address in favour of /24.
What is the address of the DHCP server? I think if it is different to the Gateway you start to get into difficulty and it is a DNS advertisment issue - it isn’t being passed through the mesh properly. Some devices are more forgiving than others.
Thanks. This bit I can do. Won’t have a screen there so might be a bit of a scurry to find it if it works. Had thought I’d always ssh in or go via web UI. I’ll set a static IP of 192.168.1.3/24 and a gateway of 192.168.1.1 and see if that gets me anywhere.
Thanks for the detail. I followed your suggestions and set a static IP of 192.168.1.3/24 a gateway of 192.168.1.1, and shut her down. Then connected Blue directly to the second port on the back of the router. No TV there so can’t see what she’s doing. Plugged her in and no sign. App won’t connect. Browser won’t connect on 192.168.1.3:8123. The router’s admin screen shows the linksys velop node connected in the adjacent port, but no sign of Blue.
Another good call, but I’ve tried that above. Removed the gateway and DNS addresses and then set mode to auto, saved, still no show.
Another ‘nother good call. I’ve tried that above as well, though. Plugged an Xbox in using the same patch lead and port and watched it immediately auto detect the dhcp server, gain an IP address (in the expected range) find the gateway and the DNS without issue. Router saw that, and the Xbox saw the world.
When auto failed on Blue, I used the values the Xbox had detected (and then tried again incrementing the ipv4 addresses’ final dotted decimal incase the router was holding on to it) and still nothing. The connection appeared green, home assistant showed eth0 as having that address. Router didn’t see Blue and Blue couldn’t see any other devices or the web.
Thanks for your ideas, as everything is a valid suggestion at this point. So far as I can work out, I’ve tried just plugging it in on auto (no), manual with known good values (no), another patch lead (no), another device on the same patch lead (fine), another device on the same port and patch lead (fine), plugging into a different mesh tower (no), plugging into the router (no), factory resetting the router then trying all again (no), factory resetting the mesh (not so much fun, still no) and I’ve still not managed to see Blue do anything with the network except tell me the link is down when I remove the lead, and that it’s back when I plug the lead in again. Seems everything works, but not blue.
Ah, done that then. It was auto, and I’ve factory reset it since then also. I can’t add a reserved DHCP because my router needs a device to connect before I can reserve an address for it, and Blue just doesn’t.
@cogneato guided me through that. Didn’t make any difference that we could ascertain.
Sorry. Im not quite sure what you mean here. Router does not see Blue plugged into a port on it and assigned auto or manual ipv4 values of 192.168.1.3/24. Router does see any other device plugged into adjacent or same port on auto or at 192.168.1.2/24. Any other device sees router. Blue does not.
When Blue was plugged into the mesh tower, the same behaviour was seen. Every other device picks up an ip in range 10.212.1.x (before factory reset of Velop) or 10.13.1.x (after factory reset) but blue does not. Blue on auto gives me an orange eth0 line. Setting Blue to a manual IP in the valid range gives me a green line for eth0, but still no ping in or out, no device detected on the router or mesh side, and nothing accessible via :8123
I’ve tried it with all of the below with no result:
DNS as 192.168.1.1 (router)
No joy plugged into router directly.
No joy plugged into mesh tower.
DNS as 10.13.1.1 (Mesh)
No joy plugged into router directly (as expected).
DNS as 8.8.8.8 (Google)
I like your thinking, but even if Blue didn’t pick up a DNS, surely it would still show on the network as an attached device? Everything else physically connected shows up in the router or mesh admin screen. Even without DNS, I should at least be able to plug it into the router directly (192.168.1.1/24) give it the static IP (192.168.1.3/24), a gateway of 192.168.1.1 and be able to ping the devices from each other, no?
That’s a good call, and I’ve ordered one. It’ll be about a week before it gets here Not knocking you at all, but I was under the impression that people on the forums didn’t really rate HA solutions connected via WiFi, and that was why “the perfect home automation hub” didn’t include it. Spending more to downgrade the reliability (admittedly from a start of zero reliability, so perhaps an upgrade after all) and move away from a standardised bit of kit produced for Home Assistant felt counter productive, but I’ll try anything
If it connects via Wi-Fi then it might suggest a faulty ethernet port. BTW, does it flash at all? You need to remove the plate to see it (which is a bit of a design fault IMHO).
I can see the LEDs it in the dark if I’m at the right angle. The port was flashing green, IIRC. The terminal notifies when the patch cable is removed, so I’m guessing the port is live, even if not quite behaving
I’ll have another look tonight. Too bright here currently and I don’t want to conduct any warranty voiding type operation if this one is going back
Ps. I’ll be gutted if it goes back. I’ve waited months for this thing to be back in stock and have been having far too much fun making floorplans on my iMac.
