couldn't start forwarding DNS server: couldn't listen to UDP socket, cause: listen udp [fe80::7d4d:3999:d4f2:5c2c]:53: bind: invalid argument.
Removed the addon and re-installed it, now giving:
[cont-init.d] adguard.sh: executing...
/var/run/s6/etc/cont-init.d/adguard.sh: line 27: null: unbound variable
[cont-init.d] adguard.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.Same here, after auto-update:
Oh wow, I literally am watching this unfold in real time.
Now, I understand I could wait for the 4.1.3 to trickle down to me. But for uninitiated and impatient folks like me, and out of curiosity, how would one manually pull the add-on update if he/she wants to?
Iāve restarted the core, reloaded the supervisor, and even rebooted the host, and not seeing it.
Hence the question.
So, in general, how do one forces update those add-ons to some specific version? Do I issue some command lines from the local console? Could this be done via the portainer add-on?
Iāve just reinstalled it too and Iām getting the same error again:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
Add-on: AdGuard Home
Network-wide ads & trackers blocking DNS server
Add-on version: 4.1.3
You are running the latest version of this add-on.
System: Home Assistant OS 5.13 (armv7 / raspberrypi4)
Home Assistant Core: 2021.5.5
Home Assistant Supervisor: 2021.04.3
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
/var/run/s6/etc/cont-init.d/adguard.sh: line 29: null: unbound variable
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Same broken system here. Though tracked my issue down to the AdGuard add-on binding to the hassio IP instead of the main IP
2021/05/20 11:47:52.822930 [info] Starting the DNS proxy server
2021/05/20 11:47:52.822963 [info] Cache TTL override is enabled. Min=30, Max=30
2021/05/20 11:47:52.822971 [info] Ratelimit is enabled and set to 20 rps
2021/05/20 11:47:52.822979 [info] The server is configured to refuse ANY requests
2021/05/20 11:47:52.822986 [info] DNS cache is enabled
2021/05/20 11:47:52.822994 [info] MaxGoroutines is set to 300
2021/05/20 11:47:52.823007 [info] Creating the UDP server socket
2021/05/20 11:47:52.823127 [info] Listening to udp://172.30.32.1:53
2021/05/20 11:47:52.823139 [info] Creating a TCP server socket
2021/05/20 11:47:52.823199 [info] Listening to tcp://172.30.32.1:53
2021/05/20 11:47:52.823334 [info] Entering the UDP listener loop on 172.30.32.1:53
2021/05/20 11:47:52.823353 [info] Entering the tcp listener loop on 172.30.32.1:53
This used to work correctly.
Changing the IP in AdGuardHome.yaml makes no difference as this is rebuilt on restart.
Hi All, Iām getting more or less same same issues - but i have no idea how to force an upgrade. Appreciate some advice on how to do this.
Or, if itās a reinstall, will uninstalling wipe my settings?
Me too, since updating to 2021-5.5 and I get this error
21-05-20 10:56:11 INFO (MainThread) [supervisor.api.security] /network/interface/default/info access from a0d7b954_adguard
21-05-20 10:56:15 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-1212621' coro=<Scheduler._run_task.<locals>._wrap_task() done, defined at /usr/src/supervisor/supervisor/misc/scheduler.py:58> exception=TypeError('an integer is required (got type str)')>
File "/usr/src/supervisor/supervisor/misc/scheduler.py", line 62, in _wrap_task
await task.coro_callback()
File "/usr/src/supervisor/supervisor/misc/tasks.py", line 416, in _watchdog_addon_application
if addon.in_progress or await addon.watchdog_application():
File "/usr/src/supervisor/supervisor/addons/addon.py", line 479, in watchdog_application
return await self.sys_run_in_executor(check_port, self.ip_address, port)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/supervisor/supervisor/utils/__init__.py", line 43, in check_port
result = sock.connect_ex((str(address), port))
TypeError: an integer is required (got type str)
21-05-20 10:56:19 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:63947 ssl:default [Connect call failed ('172.30.32.1', 63947)]
