i’m using it with DHCP, it works too
but now i changed the DNS on router side , not gonna use this addon now
because if i reboot hassos for whatever reason, then internet is down
edit: or maybe i can setup my router to make the primary dns, the adguard addon , and the secundary the google dns? that should work , right? so when hassos/addon is down, internet still works?
Quick question. Would it be possible to directly communicate to Adguard with this integration. I want to control available services based on timeslots. My kids now have homescholing and I want to block YouTube and TikTok during the ‘school hours’.
I would like to block ads on my iPhone outside my network. To achive this I would like to setup DNS over https or tls in the Ardguard Home add-on. I can’t get it work and I’m probably missing something, I hope somebody can answer these questions I have;
The profile is ‘not signed’, could that be the problem?
Webpages aren’t loading. Do I have to open the port 853 to my Home Assistant server to make this to work? What am I missing?
I tried TLS because the https port 443 was already in use by the NGINX add-on. Unfortunately I can’t find a guide to set it all up with Home Assistant, AdGuard Home, NGINX, Duckdns. I hope somebody could help me out!
Edit: Found a solution for this ‘problem’; set-up Wireguard split-tunneling to have only the DNS requests go through.
I do have another weird ‘problem’; is it normal that most of the query’s in query log are in there two times?
I use port 853 yes. I can see your (double? ) queries are quite slow too.
I would suggest using only custom client names and local subnet allowed. That way the port is open, but only known clients can connect using xxxxxxx as clientname in xxxxxxx.mydomain.com
I’ve entered my AdGuard IP into my router’s DNS server settings, so my entire network is filtered through AdGuard. It works great.
My HA is running in a VirtualBox VM. I have noticed that if/when I start the VM (from a fresh Windows boot, or from Supervisor > Reboot Host, etc.) I cannot boot up HA and I’m given a prompt to jump into an emergency console …unless I remove the DNS settings in my router beforehand. After HA starts up, I then add the IP address(es) back to my DNS settings to apply AdGuard to my network again. Is there an alternative that wouldn’t require so much involvement on my part?
Nope looks all good so problem is somewhere else I’m just confused by your setup ! If you use Adguard for DNS features it should be on a machine always on (not a VM all the more running on Windows…)
Anyone have Adguardhome sync working with adguard from home assistant? i need the user and password from adguard but cant find any info about user id and password…
I dont know why you gateway address and dns address is the same. Maybe its you network setup, but my gateway address is my router ip address and dns server is home assistant address running adguard.
Right now all my devices go trough the dns rewrite.
Well i have an google nest, when i enable protection google nest will stop working after a few hours.
