ah ok, didnt know that
I got this āalmostā working.
Via web ui I can write my request and Flex correctly executes it, casting music in my google home.
Now Iām trying to link with my google account in order to ask directly from google home.
I configured correctly my public address and forwarded the port in my router (I can access Flex TV from the internet). When I hit the link google button what I get as a result is a blank page with only āFile not foundā written on it.
Did I miss something to do?
Running on Hass.io on Rasp 3+.
That may be a bug, please open an issue in the repo for it.
Hi everybody!! Phlex has been updated as I can see in their webpage, integration with voice services updated and working again, but I canāt see how to update the addonā¦I guess will have to wait a little longer.
I am worried that there is no responses from devs anymore. I hope they are OK.
I am unable to Link Google as when I click on the button it tries to open some phlexchat.com/api.php and that file does not exist.
It would be shame if this project stopped as it was the one and only voice control for plex.
In case it didnāt - except for the Link Google problem mentioned above I am unable to use the control on the Phlex UI itself. I enter the command and it does nothing. I tried to configure the Flex TV in HA but it only shows blank screen. Thanks
Release v1.2.0
This release names the add-on to FlexTV, following up the upstream name change.
Changed
Move from Phlex to FlexTV
Maintaince -> Maintenance
Component > Integration (#53)
Updates maintenance/license year to 2020
Update add-on documentation to use new YAML configuration format
Re-branding
Update add-on config with new password & list features
Fixes some typos
Upgrades nginx to 1.16.1-r6
Upgrades add-on base image to v7.0.2
Update community forum links
Upgrades php7 to 7.3.15-r0
Questions? Join our Discord server! https://discord.me/hassioaddons
hi, I installed the addon, configured external access, enabled flex enable connect but when I try google link it receives the white page with the error:
502. Thatās an error.
The server encountered a temporary error and could not complete your request.
Please try again in 30 seconds. Thatās all we know.
The same issue for me, Iām also wondering if this still works seeing as addons in Plex are now depreciated?
yeah, trying to make Flex work with Plex, but does not work at all
This add-on is now deprecated and removed from the add-on store.
