Home Assistant Community Add-on: InfluxDB
I’ve just installed this and same issue as you dakkerd
Finally got it up and running. I had a container grafana with influxdb container. Stopped those containers. Then re-installed the add-on started ok but got 502 error.
Created a token and used that as my password.
Then opened up the db in the sidebar and viola!!"!
Now I’m confused.
No default database created. All I see is _internalmonitor.
show databases
comes up with _internal
I thought home_assisstant was supposed to be created with the add-on
Not sure is this is the right place, but… Sorry if I’m mistaken!
I’ve just updated my influxdb plug-in within hassio, and it won’t start anymore. After reinstall, the following error shows:
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…
Add-on: InfluxDB
Scalable datastore for metrics, events, and real-time analytics
Add-on version: 3.7.0
You are running the latest version of this add-on.
System: HassOS 3.13 (armv7 / raspberrypi4)
Home Assistant Core: 0.110.4
Home Assistant Supervisor: 225
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] create-users.sh: executing…
[16:54:35] INFO: InfluxDB init process in progress…
[16:54:40] INFO: InfluxDB init process in progress…
[16:54:45] INFO: InfluxDB init process in progress…
/var/run/s6/etc/cont-init.d/create-users.sh: line 56: pgrep: command not found
[cont-init.d] create-users.sh: exited 1.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…
            Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Same problem here
Thanks! The fix 3.7.1 did the trick! It’s working again.
Hello @frenck and @axil,
I am intereseted in the same feature that @axil described where collectd sends data to InfluxDB and I would like to do it from my OpenWRT router as well. The collectd add-on in OpenWRT has a settings tab where it can be pointed to the InfluxDB instance, however a listener has to be enabled and configured on the InfluxDB side.
I understand that there is some implementation by @frenck but it was not tested. If I can help with that somehow, I’m happy to do it :slight_smile:
Great job on the add-on!
Is it only me or you also noticed that the new version of influx pushes the CPU usage up? it used to be in the region of 13%-15% for me but now it has gone up substantially. Have tried the “include” trick @WouterR suggested up, with no joy. Any suggestions would be hugely appreciated.
Hey, I wondered if anybody had any good newbie-guides or tips for influx-db for anything a bit more than the basic setup, for instance i want to:
  1. Use the “native” HA-graphing for the data, most guides seems to assume I want to use grafana, which is nice and all, but doesn’t fit all that well with the “HA-look” imho.
  2. How to remove granularity over time, a lot of sensors store data very often, it takes a lot of space, I want it to for instance store every second, and after a day compact to every minute, after a month every hour and so on.
  3. Interpolating: I also have sensors that only send on change, and when i plot this, the graphs have “holes” instead of it assuming the value is the same until it changes.
hi frenck,
would you consider this once again.
Now when plugin is rock solid and super convenient.
Adding telegraph and possibility handling ha logs and different logs from other systems would be perfect.
I haven’t found any good looking log management for home assistant. influxdb log viewer looks very promising.
Update to 3.7.1 keeps crashing
How do I down grade to 3.6.x please.
	/usr/local/go/src/internal/poll/fd_poll_runtime.go:87 +0x30
internal/poll.(*pollDesc).waitRead(...)
	/usr/local/go/src/internal/poll/fd_poll_runtime.go:92
internal/poll.(*FD).Read(0x1babf2c0, 0x1c239000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
	/usr/local/go/src/internal/poll/fd_unix.go:169 +0x178
net.(*netFD).Read(0x1babf2c0, 0x1c239000, 0x1000, 0x1000, 0x1, 0x0, 0x0)
	/usr/local/go/src/net/fd_unix.go:202 +0x38
net.(*conn).Read(0x5555280, 0x1c239000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
	/usr/local/go/src/net/net.go:184 +0x58
net/http.(*persistConn).Read(0x3597180, 0x1c239000, 0x1000, 0x1000, 0x70df8, 0xc864ef4, 0x2)
	/usr/local/go/src/net/http/transport.go:1758 +0x164
bufio.(*Reader).fill(0x3cea4e0)
	/usr/local/go/src/bufio/bufio.go:100 +0x108
bufio.(*Reader).Peek(0x3cea4e0, 0x1, 0x2, 0x0, 0x0, 0x2528bc00, 0x0)
	/usr/local/go/src/bufio/bufio.go:138 +0x38
net/http.(*persistConn).readLoop(0x3597180)
	/usr/local/go/src/net/http/transport.go:1911 +0x178
created by net/http.(*Transport).dialConn
	/usr/local/go/src/net/http/transport.go:1580 +0x8f0
goroutine 131690 [select]:
net/http.(*persistConn).writeLoop(0x4e72000)
	/usr/local/go/src/net/http/transport.go:2210 +0xc0
	/usr/local/go/src/net/http/transport.go:1581 +0x90c
goroutine 57463 [select]:
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).compactCache(0x4225bc0)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:1976 +0xe4
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).enableSnapshotCompactions.func1(0xe0a8cb0, 0x4225bc0)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:505 +0x48
created by github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).enableSnapshotCompactions
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:505 +0xfc
goroutine 57464 [select]:
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).compact(0x4225bc0, 0xe0a8cc0)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:2023 +0x1b4
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).enableLevelCompactions.func1(0xe0a8cc0, 0x4225bc0)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:426 +0x50
created by github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).enableLevelCompactions
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:426 +0x114
goroutine 155551 [runnable]:
github.com/influxdata/influxdb/tsdb/cursors.(*StringArray).Exclude(0xc6195c8, 0xffffffff, 0x7fffffff, 0x0, 0x80000000)
	/go/src/github.com/influxdata/influxdb/tsdb/cursors/arrayvalues.gen.go:670 +0x2bc
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*tsmBatchKeyIterator).combineString(0x34e6320, 0xbbf71301, 0x40, 0xbbf713a0, 0x2)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/compact.gen.go:1785 +0x5e4
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*tsmBatchKeyIterator).mergeString(0x34e6320)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/compact.gen.go:1731 +0x24c
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*tsmBatchKeyIterator).merge(0x34e6320)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/compact.go:1856 +0x1e4
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*tsmBatchKeyIterator).Next(0x34e6320, 0x61686a6)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/compact.go:1716 +0x105c
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Compactor).write(0x3533740, 0x7fbf090, 0x49, 0x1e755f0, 0x34e6320, 0x18f0ab01, 0x0, 0x0)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/compact.go:1141 +0x150
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Compactor).writeNewFiles(0x3533740, 0xe, 0x2, 0x4b8a1c0, 0x6, 0x8, 0x1e755f0, 0x34e6320, 0x1, 0x1e755f0, ...)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/compact.go:1045 +0x11c
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Compactor).compact(0x3533740, 0x4b8a100, 0x4b8a1c0, 0x6, 0x8, 0x0, 0x0, 0x0, 0x0, 0x0)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/compact.go:953 +0x4a0
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Compactor).CompactFull(0x3533740, 0x4b8a1c0, 0x6, 0x8, 0x0, 0x0, 0x0, 0x0, 0x0)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/compact.go:971 +0x110
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*compactionStrategy).compactGroup(0x4b8a280)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:2208 +0xf64
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*compactionStrategy).Apply(0x4b8a280)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:2185 +0x2c
github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).compactFull.func1(0xbb43440, 0x3e3a000, 0x4b8a280)
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:2154 +0xc4
created by github.com/influxdata/influxdb/tsdb/engine/tsm1.(*Engine).compactFull
	/go/src/github.com/influxdata/influxdb/tsdb/engine/tsm1/engine.go:2150 +0xd0
goroutine 131689 [IO wait]:
internal/poll.runtime_pollWait(0xa6cfec80, 0x72, 0xffffffff)
	/usr/local/go/src/runtime/netpoll.go:184 +0x44
internal/poll.(*pollDesc).wait(0x182934b4, 0x72, 0x1000, 0x1000, 0xffffffff)
internal/poll.(*FD).Read(0x182934a0, 0x197dc000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
net.(*netFD).Read(0x182934a0, 0x197dc000, 0x1000, 0x1000, 0x1, 0x0, 0x0)
net.(*conn).Read(0xbafdff0, 0x197dc000, 0x1000, 0x1000, 0x0, 0x0, 0x0)
net/http.(*persistConn).Read(0x4e72000, 0x197dc000, 0x1000, 0x1000, 0x70df8, 0x22bf1ef4, 0x2)
bufio.(*Reader).fill(0x36ac810)
bufio.(*Reader).Peek(0x36ac810, 0x1, 0x2, 0x0, 0x0, 0xba954f00, 0x0)
net/http.(*persistConn).readLoop(0x4e72000)
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Running out of memory
2020/06/15 16:49:36 Using configuration at: /etc/kapacitor/kapacitor.conf
time="2020-06-15T16:50:04+01:00" level=info msg="Reporting usage stats" component=usage freq=24h reporting_addr="https://usage.influxdata.com" stats="os,arch,version,cluster_id,uptime"
time="2020-06-15T16:50:04+01:00" level=info msg="Serving chronograf at http://127.0.0.1:8889" component=server
[16:50:05] INFO: Starting NGinx...
runtime: out of memory: cannot allocate 32768-byte block (727744512 in use)
fatal error: out of memory
goroutine 7523 [running]:
runtime.throw(0xfa5314, 0xd)
        /usr/local/go/src/runtime/panic.go:774 +0x5c fp=0xf7573cc sp=0xf7573b8 pc=0x41644
runtime.(*mcache).refill(0xb6f9536c, 0x6d)
        /usr/local/go/src/runtime/mcache.go:140 +0xfc fp=0xf7573e0 sp=0xf7573cc pc=0x262ec
runtime.(*mcache).nextFree(0xb6f9536c, 0x26d, 0x201, 0xbe7fa000, 0x200)
        /usr/local/go/src/runtime/malloc.go:854 +0x7c fp=0xf757400 sp=0xf7573e0 pc=0x1b0f4
runtime.mallocgc(0x2a80, 0x0, 0x0, 0x3b9aca00)
        /usr/local/go/src/runtime/malloc.go:1022 +0x7a0 fp=0xf757468 sp=0xf757400 pc=0x1ba40
runtime.growslice(0xddd320, 0xbe5ae9c0, 0x13f, 0x168, 0x527, 0x800, 0x0, 0x48000000)
        /usr/local/go/src/runtime/slice.go:175 +0x11c fp=0xf757498 sp=0xf757468 pc=0x59548
On restart of host
Runs away until I stop the InfluxDB addon
Thank the stars for snapshots - back to a 3.6.x (still reports as 3.7.1) and it all works again…
Influxdb gone crazy again. No one else seeing this problem?
Gone crazy in what way?
I’m also seeing high CPU usage in InfluxDB 3.7.1.
You can see when I updated Influx.
My CPU hovers around 80-85% now. If I stop the Influx addon CPU usage goes back down to 10%.
When Influx is running ha addons stats shows this:
$ ha addons stats a0d7b954_influxdb
blk_read: 576511156224
blk_write: 950576304128
cpu_percent: 238.36
memory_limit: 968855552
With InfluxDB addon active my Pi hovers around 80% CPU, 90% memory and 75°C.
If I turn it off it drops to around 10% CPU, 45% memory and 60°C.
I’m now looking for ways to downgrade Influx DB addon. Is that possible? I have a 2 week old snapshot but have not had good experiences restoring snapshots in the past so would like to avoid that if possible.
This post might be related. Is it possible to set store-enabled = false using the envvars attribute?
I have asked several times - @frenck, is it possible to install a specific version of the addon?
Oh good, not just me then :frowning_face:
High CPU as per screenshot above.
  • Yes you can downgrade using a backup, but you lose some data of course. I’ve downgraded to 3.6.2 that way, but after some time I ran into the same issue again.
  • store-enabled = false didn’t fix it for me. Same as above, it seemed to provide some relief, but not in the long run.
In the end I think this is (partly) caused by a combination of memory limitations (on a RPi 3) and too many measurements. I store about 1500 measurements per hour (36k a day) and it feels like that is just to much. For now I’m going to upgrade to a RPi4 with 4Gb and cut back on the number of measurements.
I’m past that point. I was hoping it could be done via a configuration element.
It could be but has been fine for months. I’ve no idea how to find out how many measurements nor how to limit what is stored. How do you do that?
