I find out some strange behavior with active Pi-Hole DNS.
My Setup:
- Raspberry Pi 3 with Hassio and Pi-hole addon 0.4.0
- Setting up pi-Hole IP to my DHCP DNS Server.
Things not working so far with active pi-hole DNS on my hassio pi:
- MariaDB addon not possible to load (recorder/history/logbook not working)
- Node-Red addon not possible to install any modules
- hostname resolution not working in pi-hole WEB UI
I’m not sure if its a problem with Pi-hole it self or the addon or hassio.
Edit:
I think a solution is to set an non pi-hole DNS Server to the ResinOS Network configuration file.
https://docs.resin.io/deployment/network/2.x/
