No idea what problem I´m facing? Opening the UI from supervisor does not require a login. When using http://homeassistant:80 I can login with my user credentials but behavior is same.
See my last post here:
Home Assistant Community Add-on: Pi-hole
I’ve been using pihole regularly without Hassio, but no matter what settings I use I can’t make it work with hassio.
I have an ASUS router, if I add the local hassio ip there it doesn’t work.
I would appreciate any help to set it up, or an example please.
pihole is really a crazy thing.
Tried to use that service call and pihole is not starting, while other addons do…and i don’t have any error in log.
'1584345413987':
alias: Reboot_Addons
sequence:
- data:
addon: a0d7b954_nodered
service: hassio.addon_restart
- data:
addon: core_configurator
- data:
addon: a0d7b954_pi_hole
no error, but only pihole is not restarting.
i’m starting to really hate pihole
EDIT: seems not working via script or automation, but works with nodered.
Just make an http request node to fire when any pihole sensor became “unavailable” ( events state node ).
The http node needs to send a POST to:
http://IP:8123/api/hassio/addons/a0d7b954_pi-hole/restart
Authtentication Type bearer and insert a long live token ( generate one from HA ).
As soon as nodered read the unavailable state for the sensor, pihole is restarted.
A bit tricky but this one works.
Confirmed that this change worked for me. Many thanks.
Ok, i found something strange: if i start hassio.addon_restart with a0d7b954_pi-hole
i have this error messagge:
If i launch the script with a0d7b954_pi_hole
it starts but it does nothing.
Maybe the problem is that _ instead of - ?
Really not sure why but I cannot get my Pi Hole stats to display in my Lovelace cards - it just says everything is unavailable. It used to work but stopped last year and now I cannot work out why. Pi Hole itself works fine.
I’ve Googled it and tried every suggestion I could see - every host variation with / without port, putting verify_ssl = true, etc. Does anyone have anything else I could try?
pi_hole:
host: 'localhost:4865'
ssl: true
verify_ssl: false
api_key: ""
update_lists_on_start: false
ssl: true
certfile: fullchain.pem
keyfile: privkey.pem
interface: ''
ipv6: true
ipv4_address: ''
ipv6_address: ''
hosts: []
virtual_host: <my DuckDNS address>
In the log I just get this:
2020-03-23 20:05:56 ERROR (MainThread) [homeassistant.components.pi_hole] Unable to fetch data from Pi-hole
2020-03-23 20:11:06 ERROR (MainThread) [hole] Can not load data from *hole: localhost:4865
i have this entry in configuration.yaml
pi_hole:
ssl: false
verify_ssl: false
on both my nuc and raspPI and i can see all pihole entities.
Yeesh… I’m baffled. I changed my SSL value to false and … it started working after a few minutes (after restart).
I can’t explain why… I do use SSL…
Well, either way, thank you very much for your help.
Happy you fixed the issue
Release v4.1.2
This add-on is now deprecated and will not receive any maintenance beyond this point.
Please consider moving to the AdGuard Home add-on.
Changes
Upgrades add-on base image to v7.0.5
Upgrades gcc to 9.2.0-r4
Upgrades musl-dev to 1.1.24-r2
Upgrades php7 to 7.3.16-r0
Upgrades Pi-hole AdminLTE to v4.3.3
Adds deprecation notices
Questions? Join our Discord server! https://discord.me/hassioaddons
Since this add-on is now deprecated, I’ll go ahead and close this topic.
