You’re looking at it the wrong way. It can depend on HassOS.
By making/finding some sort of middleware to pipe the spotify audio output of a single HassOS host/hypervisor, to multiple speakers connected to the HassOS host/hypervisor, either by being directly exposed to the OS, or by connecting them via WiFi middleware, such as the SlimProto Player integration.
That way we can have audio playing on multiple speakers, and chose on which ones to play, at which time - In Hass.
And again, after the addon worked again for some months, all of a sudden I have the same issue again. All seems to work fine (spotify client connects to spotifyconnect addon, addon log shows correct entries when playing audio), but there is no audio send ouot of the Hass Blue audio jack…
It’s not hardware related, as the squeezebox addon works just fine.
Hi, I am new to the community, I have a problem with the add-on, I try to use home assistant to play the music I send through spotify, however, nothing. I use my sound system through a wired network connection, but nothing. I can play other files that are present on the server, however, sending the server to serve the sound through it does not work. what could be the fault?
Hi there. I installed the Spotify integration and Spotify Connect add-on and added the integration to a dashboard. I can play songs or playlists, as you can see in the screenshot below, but I don’t get any audio out of my PC’s speakers. I have in this case Home Assistant on an Intel NUC and both via a web browser or the HA app on my phone, there is no sound.
I would like to start an automation when spotify starts playing, to then start up my avr per IR with my harmony hub. Is this somehow possible with the addon?
I can select Home Assistant as player and it is saying it is playing both on mobile as on HA (seen via the log), however no sound? Where can I look to get this fixed?
Add-on: Spotify Connect
Play Spotify music on your Home Assistant device
Add-on version: 0.12.6
You are running the latest version of this add-on.
System: Home Assistant OS 11.2 (aarch64 / odroid-n2)
Home Assistant Core: 2023.12.0
Home Assistant Supervisor: 2023.11.6
Infelizmente não funciona.
O Spotfy do celular se conecta ao home assistant, no log é possível ver que quando dou play na música o addon recebe isso porém não reproduz o som.
Is there a way to control volume in a different way then through Spotify client? The volume of this addon is way lower than the squeezelite addon, even with volume in Spotify client turned to max.
Hi!
Im hoping that someone can help me understand some things with this add-on.
So, i installed this add-on and it works perfectly! However, i was hoping to have a media_player entity created with this, and that did not happen.
To rectify this, i used the VLC add-on which made my pi as a media_player - great! Called this “backyard speakers”.
I then installed MASS to play music/radio to this new entity from HA (not only spotify).
HOWEVER, if i am playing music from the spotify app to my spotify connect add-on, I have no way to stop the playback from HA.
ADDITIONALLY, if i choose to play something now from MASS to my “backyard speakers” media_player entity from HA, it plays OVERTOP of the spotify that is playing, as in, at the same time…
I guess i should have expected this as its two separate services with no relationship to one another, but i was still surprised.
Can somone smarter than me please help me unify things here so i can:
control media playback from HA of the spotify connect device
if playback is started from MASS, it should stop the spotify connect playback and visa-versa
Yes, this is exactly the github repo I am referring to. The link provided there does not work, also manully searching in HACS does not show any results for Spotify Connect.
It only took me 10 times reading the instructions to finally realize it: we’re talking addons here, not integrations. My home-assistant is not running HAOS, but in a Docker container, so no Add-on store.
Are there any installation instructions for running this addon in a docker and manually installing it?
