Home Assistant Community Add-on: UniFi Controller
Thanks a lot Frenck,
I already did have the devices configured using a previous controller, so this did the trick (in case anybody has the same problem):
Reset the devices using a the reset button (paperclip, small button on the back, hold for 10 seconds).
OK I removed the addon and re-added it. Started a restore and left it. After about 20 mins the the web page appeared and it had restored my config. So it seems I was impatient!
I still this error in the log though:
OpenJDK Client VM warning: You have loaded library /usr/lib/unifi/lib/native/Linux/armv7/libubnt_webrtc_jni.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
Unfortunately I could not get this add-on to work: I left it running for over an hour without result. If I subsequently restarted the add-on, login failed with unkown user/password. Hence something is failing during the config import.
I reverted back to https://github.com/stefanlaheij/hassio-addons which work fine.
I’m running the addon succesfully on my Debian install of Hassio. I have added a USG and will need to edit a file within the install (config.gateway.json). This seems to be the only way to change the mac address of the USG. How can I access that file within the docker environment, is there any way to ssh into the running container? Otherwise I may just install the controller directly in the OS and abandon the plugin.
I just install and transfer my old controller config to UniFi Controller Add-on. It’s working like a charm. Is it possible to add shortcut to Hass.io side bar?
Thanks for your efforts.
:tada: Release v0.1.2
Full Changelog
Changed
  • Upgrades UniFi to v5.8.24
Hi Guys,
Is there any way to access the unifi controller config files? I have a need to edit the config and add some code that disables NAT on my USG so that I can let my pfsense box handle nat / routing
Where is this file located?
<unifi_base>/data/sites/site_ID/config.gateway.json.
Is there any conflict between using this and the inbuilt mqtt on 1883 / 8883 ports on hass.io. was thinking about installing this but had some vague recollection of there being an issue?
Hi Kiwi,
I use both and haven’t had any issues. I do however run hassio on an Intel NUC for better performance.
Thanks. I’ll give it a whirl then. I’m also looking to eventually repurpose my old nuc as well.
I’m trying to use https://www.home-assistant.io/components/device_tracker.unifi/. It reports Failed to connect to Unifi: Login failed - status code: 400 at startup. I suspect that it is since Unifi Controller addon isn’t started yet.
Anyone here that that has a working device_tracker.unifi and any suggestions?
This is great! Thanks so much! Would it be possible to add the beta version of the controller as well? I am currently running version 5.9.4.
I installed the controller and it works great. Thank you.
I’m considering this at this point.
Im unable to access the web UI, and the logs are being filled with errors like this, any ideas? :
org.tuckey.web.filters.urlrewrite.UrlRewriteFilter INFO: destroy called
Exception in thread “launcher” org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘Object’ defined in class com.ubnt.service.AppContext: Instantiation of bean failed; nested exception is org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [com.ubnt.service.Object.O0OO com.ubnt.service.AppContext.Object()] threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘dbService’ defined in class com.ubnt.service.AppContext: Invocation of init method failed; nested exception is com.mongodb.MongoCommandException: Command failed with error -1: ‘db side execution is disabled’ on server 127.0.0.1:27117. The full response is { “ok” : 0.0, “errmsg” : “db side execution is disabled” }
at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:597)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1055)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:951)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:487)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:458)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:296)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:223)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:293)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:628)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:932)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:479)
at org.springframework.context.annotation.AnnotationConfigApplicationContext.(AnnotationConfigApplicationContext.java:73)
at com.ubnt.service.B.õO0000(Unknown Source)
at com.ubnt.service.B.Õ00000(Unknown Source)
at com.ubnt.ace.Launcher.main(Unknown Source)
Caused by: org.springframework.beans.factory.BeanDefinitionStoreException: Factory method [com.ubnt.service.Object.O0OO com.ubnt.service.AppContext.Object()] threw exception; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘dbService’ defined in class com.ubnt.service.AppContext: Invocation of init method failed; nested exception is com.mongodb.MongoCommandException: Command failed with error -1: ‘db side execution is disabled’ on server 127.0.0.1:27117. The full response is { “ok” : 0.0, “errmsg” : “db side execution is disabled” }
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:181)
at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:586)
… 15 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name ‘dbService’ defined in class com.ubnt.service.AppContext: Invocation of init method failed; nested exception is com.mongodb.MongoCommandException: Command failed with error -1: ‘db side execution is disabled’ on server 127.0.0.1:27117. The full response is { “ok” : 0.0, “errmsg” : “db side execution is disabled” }
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1512)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:521)
at org.springframework.context.annotation.ConfigurationClassEnhancer$BeanMethodInterceptor.intercept(ConfigurationClassEnhancer.java:305)
at com.ubnt.service.AppContext$$EnhancerBySpringCGLIB$$d0b6a376.dbService()
at com.ubnt.service.AppContext.Object(Unknown Source)
at com.ubnt.service.AppContext$$EnhancerBySpringCGLIB$$d0b6a376.CGLIB$Object$0()
at com.ubnt.service.AppContext$$EnhancerBySpringCGLIB$$d0b6a376$$FastClassBySpringCGLIB$$d25bb5f5.invoke()
at org.springframework.cglib.proxy.MethodProxy.invokeSuper(MethodProxy.java:228)
at org.springframework.context.annotation.ConfigurationClassEnhancer$BeanMethodInterceptor.intercept(ConfigurationClassEnhancer.java:293)
at com.ubnt.service.AppContext$$EnhancerBySpringCGLIB$$d0b6a376.Object()
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:160)
… 16 more
Caused by: com.mongodb.MongoCommandException: Command failed with error -1: ‘db side execution is disabled’ on server 127.0.0.1:27117. The full response is { “ok” : 0.0, “errmsg” : “db side execution is disabled” }
at com.mongodb.connection.ProtocolHelper.getCommandFailureException(ProtocolHelper.java:115)
at com.mongodb.connection.CommandProtocol.execute(CommandProtocol.java:114)
at com.mongodb.connection.DefaultServer$DefaultServerProtocolExecutor.execute(DefaultServer.java:168)
at com.mongodb.connection.DefaultServerConnection.executeProtocol(DefaultServerConnection.java:289)
at com.mongodb.connection.DefaultServerConnection.command(DefaultServerConnection.java:176)
at com.mongodb.operation.CommandOperationHelper.executeWrappedCommandProtocol(CommandOperationHelper.java:216)
at com.mongodb.operation.CommandOperationHelper.executeWrappedCommandProtocol(CommandOperationHelper.java:187)
at com.mongodb.operation.CommandOperationHelper.executeWrappedCommandProtocol(CommandOperationHelper.java:161)
at com.mongodb.operation.CommandOperationHelper.executeWrappedCommandProtocol(CommandOperationHelper.java:134)
at com.mongodb.operation.CommandOperationHelper.executeWrappedCommandProtocol(CommandOperationHelper.java:124)
at com.mongodb.operation.CommandWriteOperation.execute(CommandWriteOperation.java:55)
at com.mongodb.Mongo.execute(Mongo.java:845)
at com.mongodb.Mongo$2.execute(Mongo.java:828)
at com.mongodb.DB.executeCommand(DB.java:724)
at com.mongodb.DB.doEval(DB.java:565)
at com.mongodb.DB.eval(DB.java:579)
at com.ubnt.service.OoOO.OOoo.õO0000(Unknown Source)
at com.ubnt.service.OoOO.S.ö00000(Unknown Source)
at com.ubnt.service.OoOO.S.do(Unknown Source)
at com.ubnt.service.OoOO.S.super(Unknown Source)
at com.ubnt.service.OoOO.oOoo.Ò00000(Unknown Source)
at com.ubnt.service.OoOO.oooO.void(Unknown Source)
at com.ubnt.service.OoOO.OOoo.afterPropertiesSet(Unknown Source)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1571)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1509)
… 35 more`
I have the same issue, is there anyway around using port 8080?
I would suggest just using the Mosquitto broker add-on.
Hey guys, quick question… if I already have a UniFi CloudKey running the Controller software, is there any real benefit to justify swapping it out with this add on?
