Release v2.0.0
Full Changelog
Major release time!
This is an exciting release, as this release adds support for aarch64 based systems.
E.g., running the 64 bits Home Assistant Operating System on a Raspberry Pi 4 or Hardkernel ODROID-N2!
Please be aware, this add-on can be pretty heavy. On low memory devices (e.g., Raspberry Pi 4 with 1Gb of memory), I would still not recommend using this add-on.
Another visible thing is the rebranding of Home Assistant, which has been reflected on the add-on. The hassio command-line tool has been replaced by the newer and updated ha version. (Donāt worry, Iāve added a backward-compatible layer with a warning if you still use the old command).
All extensions provided by the add-on, are now marked as ābuiltinā. This means they no longer show up in the extensions list. Other than that, it doesnāt change a thing. It makes future updates to the add-on easier.
Also added in this release: Hooking up with the official Mosquitto and MariaDB add-ons (if installed).
If you use the MQTT tools (mosquitto_pub or mosquitto_sub) from the terminal inside VSCode, they will automatically connect, authenticate and work with the Mosquitto core add-on. Allowing for easy debugging
For the mysql command-line tool, the same has been done. If you have installed the MariaDB add-on, running mysql from the command-line, drops you straight in!
Breaking change: Direct access to the add-on has been removed in favor of easier maintenance and Ingress. With Home Assistant now having Safe Mode, direct access has lost its importance.
Changes
Upgrades add-on base image to v5.0.0
Update add-on documentation to use new YAML configuration format
Re-branding
Update add-on config with new password & list features
Updates for upstream Supervisor changes
Remove direct access support
Updates the Home Assistant CLI to v4.0.1
Fixes some typos
Remove unused dependencies
Fix broken semver link
Install extensions from Marketplace, removes a stage layer
Adds aarch64 support
Add aarch64 CI/build
Mark delivered extensions as builtin
Improve download if extensions during build
Fixes linter warnings
Add hassio fallback command for backward compatibility
Add hook up with the MQTT service
Add hook up with the MySQL service
Remove log spam about extensions during add-on start
Fix old extension cleanup
Corrects forum URL links
Questions? Join our Discord server! https://discord.me/hassioaddons
Enjoying my add-ons? Consider supporting my work:
https://github.com/sponsors/frenck or https://patreon.com/frenck
