Home assistant community addons : Formerly the Logitech Media Server (LMS) & Squeezelite
Yes thats a bug please log an issue in github with logs config details etc and I will look into it… It should not prompt.
Latest and Last version of LMS has arrived (8.4.0). Where will the open source work go? Will LMS continue to thrive? Thanks,
It has a very very strong community and will (IMHO) survive.
For those who don’t know what we are referring to, see
https://forums.slimdevices.com/forum/user-forums/logitech-media-server/1673928-logitech-media-server-8-4-0-released#post1674057
And the thread linked in the first post there.
Indeed Logitech has become a constraint on more community contributions
Thanks for the update. Just getting started with LMS within HA. Plex is… well Plex so trying to simplify to LMS and hoping this solution has ‘legs’.
Question: Media (in HA) sees my DLNA Renderers (3 - Arylic 50 + speakers) but they do not show up in LMS. I’ve enabled in Settings (turned on DLNA discovery) but still no love. Maybe missed something obvious!
Thoughts? thx
@nickrout Already talk of next version 8.5 to deal with complete separation from mySB server. Which should have happened earlier. A lot of support.
Yep all very positive.
Hello Everyone.
type: button
tap_action:
  action: navigate
  navigation_path: http://ha-ip:8123/fc57b866_lms/dashboard
entity: xyz
I have a button in my dashboard which navigates to LMS dashboard. How do i get back to the main dashbaord? The back button doesnt take me to the main dashbaord. Also the sidebar is hidden, it has to be kept hidden only.
Kindly guide.
Hello!
Can someone tell me if it is possible to attach a USB Drive with hfs format (macOS) to the Home Assistant Pi 4 and use it with this LMS Add-On?
I am using a Pi 4 with piCorePlayer and LMS in the moment and there it is possible without any problem (I am mounting it read-only as it will not be written to by LMS). I only have to install the neccessary drivers for hfs.
@carsten_h probably if you do a supervised install, as I doubt HAOS will allow you to add said drivers but might me worth at least testing. It’s certainly the intention of the add on to support flexible disk layout, nfs and usb storage.
In the meantime I set up a LXC-container in my Proxmox server for LMS and Squeezelite and there I have no problems in mounting hfsplus drives.
Thank you!
Hello Everyone,
I am not able to play .m4a files from logitech media server. .mp3 files are playing fine.
Kindly guide how to fix this.
Thank you
It’s probably too do with transcoding settings being wrong, it the transcoding binary not being included in the docker container. @pssc may be able to comment.
I just checked with music assistant, the same files are playing perfectly.
@pssc kindly guide how to fix this for LMS.
Thank you
You may need to consult the slimdevices forum.
already done that.
[16:49:41.938] AddCastDevice:1006 [0x684378]: adding renderer (Bedroom speaker) with mac xxxx-xxxxxxxx
[16:49:41.941] mDNSsearchCallback:882 Updating configuration /config/lms/prefs/castbridge.xml
[16:49:41.942] slimproto:885 squeezelite [0x6061a8] <=> player [0x684378]
[16:49:41.943] slimproto:886 [0x6061a8] connecting to 192.168.1.15:3483
[16:49:41.943] UpdateCastDevice:339 [0xffffb005e330]: changed ip port 192.168.1.56:32033
[16:49:41.943] mDNSsearchCallback:812 [0x6828e8]: refreshing renderer (Speakers)
[16:49:41.943] UpdateCastDevice:339 [0xffffb0062100]: changed ip port 192.168.1.56:32232
[16:49:41.944] mDNSsearchCallback:812 [0x683630]: refreshing renderer (Home group)
[16:49:41.944] slimproto:916 [0x6061a8] connected
[16:49:41.945] sendHELO:131 [0x6061a8] cap: CanHTTPS=1,Model=squeezelite,ModelName=CastBridge, AccuratePlayPoints=0,HasDigitalOut=1,MaxSampleRate =96000,aac,ogg,ops,ogf,flc,wav,aif,pcm,mp4,m4a
[16:49:41.957] read_bytes:78 [s-0xffffb005a100]: SSL error code 5 (err:0)
[16:49:41.957] CastSocketThread:579 [0xffffb005e330]: SSL connection closed
[16:49:42.030] read_bytes:78 [s-0xffffb0062290]: SSL error code 5 (err:0)
[16:49:42.030] CastSocketThread:579 [0xffffb0062100]: SSL connection closed
[16:49:44.255] CastConnect:239 [0x684378]: SSL connection opened [0xffffb0067060]
[16:49:44.256] sq_callback:407 [0x684378]: LMS volume (0…128) 1 => CC 0.0300
[16:49:51.327] sendSTAT:165 [0x6061a8]: STAT:[STMf] msplayed 0
[16:49:51.327] CastStop:309 [0x684378]: Stop w/o session or connect
[16:49:51.361] sq_callback:407 [0x684378]: LMS volume (0…128) 1 => CC 0.0300
[16:49:51.363] process_strm:234 [0x6061a8] strm command s
[16:49:51.363] process_strm:304 [0x6061a8], strm s autostart: 1 transition period: 10 transition type: 0 codec: a
[16:49:51.363] sendSTAT:165 [0x6061a8]: STAT:[STMf] msplayed 0
[16:49:51.377] sq_callback:327 [0x684378]:
artist:No Artist
album:No Album
title:Om Namah Shivay
duration:1114285
live_duration:-1
position:0
cover:
index:0
[16:49:51.381] LaunchReceiver:188 [0x684378]: Launching receiver 1
[16:49:51.381] CastLoad:177 [0x684378]: Queuing LOAD
[16:49:51.381] sq_callback:355 [0x684378]: current URI (s:0) http://192.168.1.15:49665/bridge-1.mp4
[16:49:51.381] process_start:1268 [0x6061a8]: codec:*, ch:0, s:53, r:0
[16:49:51.381] sendSTAT:165 [0x6061a8]: STAT:[STMc] msplayed 0
[16:49:51.381] sq_callback:407 [0x684378]: LMS volume (0…128) 1 => CC 0.0300
[16:49:51.716] CastSetDeviceVolume:373 [0x684378]: Queuing SET_VOLUME
[16:49:51.716] CastPlay:262 [0x684378]: Queuing PLAY
[16:49:54.399] CastSocketThread:656 [0x684378]: Receiver launched
[16:49:54.399] ProcessQueue:483 [0x684378]: Processing LOAD (id:2)
[16:49:54.868] ProcessQueue:448 [0x684378]: Processing VOLUME (id:4)
[16:49:54.912] http_read_line:1096 fd: 22 read error: Connection reset by peer
[16:49:54.912] http_parse_simple:1019 cannot read method
[16:49:54.912] handle_http:489 [0x6061a8]: http parsing error (null)
[16:49:54.932] ProcessQueue:471 [0x684378]: PLAY un-queued but no media session
[16:50:59.166] UpdateCastDevice:339 [0xffffb005e330]: changed ip port 192.168.1.17:32033
[16:50:59.167] UpdateCastDevice:339 [0xffffb0062100]: changed ip port 192.168.1.17:32232
[16:50:59.167] mDNSsearchCallback:791 [0x6828e8]: removing renderer (Speakers)
[16:50:59.167] slimproto_close:957 [0x5fd998] slimproto stop for Speakers
[16:50:59.392] DeleteCastDevice:379 [0x6828e8]: Cast device stopped
[16:50:59.392] mDNSsearchCallback:791 [0x683630]: removing renderer (Home group)
[16:50:59.392] slimproto_close:957 [0x601da0] slimproto stop for Home group
[16:50:59.592] DeleteCastDevice:379 [0x683630]: Cast device stopped
here is the log… If this helps…
stream is failing
Try proxing via LMS rather than leting the player stream direct?
Solved… thank you so much
When will we get the v8.4.0 update for the LMS addon ?
Kindly reply
Thank you
@Vandana soon I am testing depends on work and children :slight_smile:
